Why is my phone showing SOS only?
My phone suddenly went to SOS only mode, and I can’t make calls or send texts. I checked my network settings but everything looks fine. I need help fixing this issue as I’m unable to communicate. Any advice would be appreciated.
If your phone is showing SOS only, it typically means it can’t find a signal from your carrier but can still connect to emergency services. Before you panic and call it the apocalypse, here’s a checklist:
  1. Restart Your Phone: Seriously, sometimes that’s all it takes. Classic IT advice—turn it off, turn it on.
  2. Check Airplane Mode: Maybe you accidentally turned it on? Toggle it off/on just to be sure.
  3. SIM Card: Your SIM might’ve shifted like it’s on vacation. Reseat it or clean it gently. It could also be faulty, so swap it if possible.
  4. Check Coverage: Are you in the middle of nowhere or a building with steel walls? Move around to test.
  5. Network Settings Reset: Go nuclear—reset network settings. You might lose wifi passwords, but it can solve connectivity issues.
  6. Carrier Outage: Sometimes it’s not you, it’s them. Check with your carrier for outages in your area.
If none of that works, well, maybe your phone decided to just ‘phone it in’ today. Could be time for a service repair or carrier store trip. It’s annoying, but hey, at least SOS still works. Priorities, right?
SOS only, huh? Yeah, been there—it’s like your phone goes full drama mode. @suenodelbosque has some solid steps, but lemme add some extras (and disagree a little because why not?).
  1. Carrier Settings Update: Sometimes your phone’s screaming for an update. Go to your phone’s settings and check if a carrier settings update is waiting. It’s sneaky like that.
  2. Roaming Settings Check: If you’re near a border or traveling, your phone might be confused about which network to latch onto. Check your roaming settings just in case.
  3. Network Preference: Sometimes the auto-network selection freaks out. Manually select your carrier in the settings. Don’t wait for your phone to figure it out—it clearly can’t right now.
  4. Device Health: Hate to say it, but hardware could be an issue. If your antenna’s damaged, no amount of resets will save you. Take a peek at your phone’s repair history (or lack thereof).
Honestly, resetting network settings feels more like a last-ditch move—@suenodelbosque is more optimistic than I am with that tip. It’s often the carrier messing up, so maybe give them a call… oh wait, you can’t. Use another phone to check if there’s a widespread issue. Phones are great… when they work, right? Always has to be something. SMH.
Try this simple order:
  1. Turn Airplane mode on for 30 seconds, then turn it off.
  2. Power the phone off for 1 full minute, then turn it on.
  3. Pop the SIM tray out, wipe the SIM with a clean dry cloth, reseat it firmly.
  4. Test the SIM in another phone, or another SIM in your phone.
If your SIM works fine in another phone, go straight to a repair shop or your carrier store.
