What’s the Most Reliable Way to Connect a Garmin Venu 3 to a MacBook?
What are the most convenient and reliable methods to link the Venu 3 with a Mac? Should I be using native Garmin software, or are third-party file transfer tools like Android File Transfer or MacDroid better for this? Any advice or tips from Mac users would be greatly appreciated!
Here is what I’ve learned and what has worked for me:
1. The Official Native Way: Garmin Express
First off, definitely try Garmin Express. It’s Garmin’s official desktop application for Mac. It’s the easiest and most reliable tool for software updates, managing music (like loading local audio files), syncing data to Garmin Connect, and installing watch faces or apps via Connect IQ.
  • Tip: Make sure to close Garmin Express completely if you plan on trying any other file transfer programs, because macOS will only allow one application to communicate with an MTP device at a time.
2. Third-Party File Transfer Apps
If you specifically want direct file-level access (like accessing raw.FIT files, adding custom maps, or downloading screenshots), Android File Transfer was a good option, but it has been officially discontinued and is no longer supported or available for download from Google.
MacDroid looks like a decent replacement, although I haven’t tried it myself. I know that it mounts MTP devices directly into Finder, making your device behave like a regular drive so you can drag and drop files back and forth.
3. Other Alternative Methods to Connect / Transfer
Here are a few additional options depending on what you’re trying to achieve:
  • Wireless Sync via Garmin Connect (Mobile/Web): If your goal is just to view health metrics, workout logs, and sync activities, you don’t actually need a cable connection at all. Sync your Venu 3 via Bluetooth to the Garmin Connect mobile app on your phone, and all your data will instantly be accessible on your MacBook through any browser via Garmin Connect Web.
For routine syncing, Bluetooth is simpler; for Mac detection, the cable or USB hub is usually the weak link. Use the Garmin cable or a known data-capable replacement directly into the MacBook with Garmin Express, and keep MacDroid for manual file access.
The Venu 3 is not supposed to appear on a Mac like a normal USB drive. It uses MTP, and macOS does not mount Garmin MTP devices as ordinary Finder volumes, so “nothing appeared on the desktop” does not necessarily mean the cable failed.
For the least hassle, use Garmin Connect on your phone for everyday activity syncing and Garmin Express when you need firmware updates or want to load local music from the Mac. That covers nearly everything most Venu 3 owners actually need.
MacDroid only makes sense when you specifically need folder-level access, such as copying a FIT file manually. I would treat it as an occasional utility rather than the main connection method. Copy files out rather than rearranging or deleting folders on the watch. Android File Transfer is no longer worth building a workflow around, and custom maps are not a meaningful use case for the Venu 3 anyway.
Garmin Express is not the best default connection method if all you want is activity and health-data syncing. The Venu 3 is designed to send that data through Garmin Connect on your phone, after which you can view it on the Mac in a browser. Plugging the watch into the Mac for every sync adds hassle without much benefit.
Use the USB connection for specific jobs: firmware recovery, local music transfers, or manual access to files. Garmin Express is the safer choice for the first two. MacDroid is useful for the last one, but it does not replace Garmin’s software. It simply gives macOS a way to browse the watch’s MTP storage.
A detail that causes a lot of confusion is application conflict. Garmin Express may keep running in the background even after its window is closed. If MacDroid cannot see the watch, fully quit Express from the menu bar before reconnecting. Likewise, close MacDroid before opening Express. Only let one program talk to the watch at a time.
For manual FIT-file work, copy the file onto the Mac first and then import or edit it. Avoid treating the watch like a general-purpose external disk, especially for moving folders around or deleting files you do not recognize. Android File Transfer is effectively a dead end now, so I would not install an old copy just for this. The practical setup is Garmin Connect for routine use, Express for Garmin-managed tasks, and MacDroid only when you genuinely need file-level access.
Loading music onto the watch and pulling a raw FIT file off it are two different jobs, and people keep lumping them together. Express handles the first cleanly, while MacDroid only earns its spot for that second case when Finder gives you nothing. Treat them as separate tasks, not competing methods.
MacDroid is not a more reliable replacement for Garmin Express. They handle different jobs. Garmin Express is the right choice for updates, Garmin-managed syncing, and loading personal music. MacDroid only gives you access to the watch’s MTP file storage.
There is a mildly annoying Mac-specific catch with music: Garmin’s instructions say Express reads from the Apple Music/iTunes library. If your MP3 or M4A files are just sitting in Downloads, you may need to import them into Music before Express sees them. Streaming-service playlists are handled through the provider’s watch app rather than copied over with MacDroid.
For normal use, I would skip the Mac connection entirely and let Garmin Connect on the phone sync your activities. Plug the watch into the Mac only when there is a specific reason. Install MacDroid if you eventually need to retrieve a raw FIT file or screenshot, but paying for an MTP utility “just in case” seems unnecessary.
Android File Transfer should be left out of the equation. Even when it was maintained, MTP on macOS could be temperamental. The sensible setup is Garmin Connect for daily data, Garmin Express for supported USB tasks, and a file browser only for the occasional manual copy.
If the Venu 3 appears under USB in System Information but not in Finder, that’s expected; if it does not appear under USB at all, MacDroid is not going to perform any MTP magic. Check that before installing more software. A direct data-capable cable, clean watch contacts, an unlocked Mac, and accepting any “Allow accessory” prompt matter more than which transfer app has the nicer icon.
Once the Mac actually sees it, use Garmin Express for supported Garmin jobs. Use Garmin Connect through the phone for ordinary syncing. MacDroid is only worth installing when you have a specific file to retrieve or copy and Express cannot do it. Buying an MTP app merely because the watch failed to appear on the desktop is paying to solve normal macOS behavior.
So I would diagnose the physical USB connection first, then install the minimum software needed. Android File Transfer is obsolete, and piling three device managers onto the same Mac tends to create the sort of “convenience” that requires an afternoon of quitting background processes.
A folder-level copy of the Venu 3 is not a proper backup of the watch. MacDroid may expose visible files, but it will not preserve every setting, app configuration, or synced health record in a form you can simply restore later. I would not choose an MTP tool because you want “more control” unless you have a specific file to retrieve.
For reliability, keep the jobs separate: let Garmin Connect handle normal activity and health syncing through your phone, and use Garmin Express for updates or personal music. MacDroid is reasonable for an occasional raw FIT file or screenshot, but copy files to the Mac before working with them. Avoid editing, renaming, or cleaning up folders directly on the watch, since the apparent clutter may be files Garmin expects to manage itself.
So the practical answer is that there is no single best Mac connection method. Express is the supported tool, while MacDroid is a narrow workaround for Finder’s lack of MTP browsing. If Express recognizes the watch and you do not need manual files, installing another device manager mostly creates another possible conflict.
