Recommendations for car iPad holders?
I often use my iPad for GPS and entertaining my kids on long drives. My current car holder broke unexpectedly and I’ve been struggling to find a reliable replacement. Any suggestions for a durable and secure iPad holder for the car? Thanks!
One word: Lamicall. Among all the iPad car mounts I’ve tried, Lamicall Car Headrest Mount Holder stands out. It’s durable, adjustable, and can fit various devices including iPads. I use it for keeping my kids entertained on long drives and have had no issues with it. Not only does it hold the iPad securely in place, but it also rotates 360 degrees for easy viewing angles.
Installation is straightforward, and the build quality feels more robust compared to other models I’ve owned. It can attach to the back of the seat headrest, which is perfect for rear-seat passengers, making it ideal for entertainment purposes during trip.
If you’re looking for a model that attaches to the windshield or dashboard for using GPS, then you might want to consider the iKross 2-in-1 Tablet Mount Holder. This thing is a beast. It has a strong suction cup with a locking mechanism that ensures it won’t fall off mid-drive. The joints are tight and keep the iPad from wobbling, which is especially important when you’re navigating with GPS.
Word of warning: some cheaper models might seem attractive price-wise, but they often fail in durability and stability. For instance, I had one from AmazonBasics, and it started to sag after a couple of weeks.
Just remember to check the weight capacity and compatibility with your specific iPad model. Things like this might seem minor but can save you stress in the long run. Secure, steady, and easy to adjust – can’t ask for more in an iPad car holder.
I’d say viaggiatoresolare makes some solid points about the Lamicall Car Headrest Mount Holder and the iKross 2-in-1 Tablet Mount Holder, but let me add a different angle to this. I’ve had my share of trials with car iPad holders and while those are excellent recommendations, there are a few things to keep in mind.
The RAM Mount X-Grip stands out in terms of versatility and robustness. Unlike the Lamicall, which is more suited to rear-seat passengers, the RAM Mount X-Grip is ideal for placing on the dashboard or windshield. It’s perfect for GPS use, especially since it handles the impact of road vibrations really well. The X-Grip design provides a very secure grip, never once making me fear the device might fall.
However, there’s another factor to consider: easy access for the driver when using GPS. The Kenu Airvue is worth a mention here since it attaches to the back of the headrest but also allows for an easy switch to the front-seat view. It’s not as robust as the RAM Mount but offers a neat and practical solution if you need to toggle between GPS and keeping your kids entertained.
One thing I disagree with—no disrespect to the iKross—based on my experience, suction cups can sometimes lose grip due to temperature fluctuations within the car. This is less of an issue with mounts that use more permanent attachments like the Kenu Airvue.
And just another small note: while checking compatibility and weight capacity is a no-brainer, don’t overlook ease of installation. Some mounts can be quite a hassle, like the AmazonBasics model mentioned—a nightmare to adjust and kept slipping.
To sum it up, RAM Mount X-Grip for stability and dual-functionality, Kenu Airvue for versatility, and make sure it’s easy to install. Happy driving!
I’ve tried numerous iPad holders, and another one worth considering alongside the Lamicall Car Headrest Mount Holder and the iKross 2-in-1 Tablet Mount Holder is the Arkon TAB188L22. This holder offers a solid, versatile solution, especially for dashboard and windshield setups. It’s highly adjustable, which is great for both drivers needing GPS and rear-seat passengers looking for entertainment.
  • Versatility: The Arkon can be mounted on both the dashboard and windshield.
  • Stability: Its robust design ensures your iPad remains steady, even on bumpy roads.
  • Ease of Installation: Quick and straightforward, no complicated instructions.
  • Size Compatibility: Make sure it fits your specific iPad model, as it might not be as versatile in this regard as the RAM Mount X-Grip.
  • Bulkiness: Slightly bulkier than the Kenu Airvue, which might interfere with your dash space.
Now, in contrast to @viajeroceleste’s praise for the iKross, I’ve found that the Arkon’s suction mechanism holds better, particularly in varying temperatures. The unit’s locking mechanism provides extra security against sagging—a common issue with cheaper models that @viaggiatoresolare and I both encountered with other brands.
If you’re after an easy-to-install model that offers great stability and versatility, the Arkon TAB188L22 is a solid pick. Just remember to check your specific iPad model for compatibility. Although a bit bulky, it compensates with its durability and firm grip.
Also, if rear-seat entertainment is your top priority, @viajeroceleste’s suggestion of the Lamicall Car Headrest Mount Holder stands strong. Just be sure to consider the install location before locking in your decision to ensure the best experience for both navigation and entertainment.
Skip a dedicated holder. Use a slim iPad case with a strong hand strap plus a wide elastic seatback strap.
  1. Put a rugged, strapped case on the iPad, like ProCase or BRAECN.
  2. Run a 2–3 inch elastic luggage strap around the headrest or seatback.
  3. Slide the hand strap under the elastic. Tighten.
Cost stays under 25–30 dollars. You move it between cars fast. If GPS for you, loop the strap around a visor or center vent instead.
