Need help working with a virtual serial port over Ethernet
I’m trying to set up a virtual serial port over Ethernet so I can access a remote device as if it were directly connected to my PC, but I’m running into issues with connectivity and data not transmitting reliably. I’m not sure if I’ve misconfigured the virtual COM settings, the network parameters, or the server/client side software. Can someone walk me through the correct setup steps, best practices, and common pitfalls for using a virtual serial port over Ethernet, including any recommended tools or configurations for stable communication?
Sounds like you’re basically trying to get a “remote serial cable” working over TCP/IP and running into the classic trio of problems: wrong mode, flaky drivers, or timing issues.
A few things to check that usually bite people:
  1. Figure out if your device is a TCP server or client
    Most serial device servers listen on a TCP port (like 23, 2000, 4001).
    Your virtual COM driver on the PC should connect as a client to that IP and port.
    If both sides are trying to act as servers, nothing will ever connect.
  2. Use a real virtual COM solution, not some half baked driver
    Windows built-in stuff will not magically create a serial port over Ethernet.
    Tools like Serial to Ethernet Connector are purpose built for exactly this. They create a proper COM port on your PC and forward all data over TCP to the remote side.
    It also lets you tune timeouts, keepalives, and reconnection which is huge for reliability.
  3. Test the raw TCP link first
    Before blaming the “COM” side, open telnet <ip> <port> or use nc or PuTTY in raw TCP mode.
    • If you can connect and see data, Ethernet path is fine.
    • If it drops or stalls, you’ve got network / device server issues, not COM issues.
  4. Handshake & buffer settings
    A ton of “data not transmitting reliably” issues are just flow control mismatches.
    • Match baud, data bits, parity, stop bits exactly to the remote serial device.
    • If the hardware device uses RTS/CTS and your virtual COM software ignores it, you’ll get weird truncation and stalls.
      In tools like Serial to Ethernet Connector you can tweak buffer sizes and flow control so it behaves like a real UART.
  5. Timeouts and keepalives
    Long idle connections over WiFi or flaky routers can silently die.
    Enable TCP keepalive or auto reconnect in your virtual COM software so the link comes back on its own instead of just hanging forever.
  6. What you’re actually trying to set up
    What you want is essentially a virtual COM interface over a LAN connection so your software still talks to COM3 or COM5, but in reality it’s sending bytes over Ethernet. Something like
    creating a reliable virtual serial interface via Ethernet
    describes that workflow pretty well.
If your use case is simple like “one PC talks to one serial device,” set the remote box as TCP server, install Serial to Ethernet Connector on the PC, create a client virtual COM that connects to that IP and port, clone the serial params, and then test with a dumb terminal (Tera Term, RealTerm) before you throw your real app at it.
If it still glitches after that, post the exact hardware model, baud rate, and what virtual COM driver you’re using, because at that point it’s usually some vendor specific nonsense.
Couple more angles to check that complement what @jeff already covered, without just rehashing the same stuff.
1. Verify what your serial-side actually expects
Everyone focuses on IP/ports, but a lot of “unreliable” behavior is because the Ethernet box is trying to be clever:
  • Some device servers add a packetization timeout or frame delimiter (e.g. send TCP data only after X bytes or Y ms).
    If your protocol is very timing sensitive or expects byte‑by‑byte streaming, this can break things badly.
  • Look for settings like:
    • “Flush buffer after timeout”
    • “Send on character”
    • “Delimiter-based send”
For pure “it should look like a wire” behavior, you usually want:
  • Packetization timeout as low as the device allows, or disabled
  • No delimiter framing
Otherwise you see things like: first command works, second one half arrives, third gets buffered, etc. Super annoying to debug.
2. Disable any “smart” protocol modes
Some serial-over-LAN gear has special modes like:
  • Modbus gateway
  • RFC2217 extension mode
  • Reverse telnet with escape sequences
If your app expects a dumb serial port and the device server is in some “smart” protocol mode, you’ll get random extra bytes or disconnects when the box thinks it sees an escape or control sequence.
In the config, make sure it is set to something like Raw TCP or “transparent mode,” nothing protocol-aware.
3. Check for Nagle vs. low-latency requirements
If your protocol sends lots of tiny packets (e.g. 1–4 bytes with immediate response), Nagle’s algorithm can introduce jitter and weird latency that looks like “things are dropping.”
  • On some device servers you can turn off Nagle (often called “low latency” or “disable Nagle”).
  • Some virtual COM drivers also let you tweak this.
If you see bursts of data instead of a smooth stream in a sniffer like Wireshark, this is one thing to try.
4. Try a different virtual COM driver
I’ll actually slightly disagree with the idea that “any decent virtual COM” is fine. Some are pure trash, and Windows built-in stuff is definitely not magic.
If you’re not already, try a purpose-built solution like Serial to Ethernet Connector. It typically:
  • Creates a local COM port that most legacy apps accept without complaint
  • Lets you tune buffer sizes, reconnection behavior, and timeouts
  • Handles weird edge cases like apps that open/close COM repeatedly or change port settings mid-session
If you need something you can quickly test on your machine, grab it from here:
download reliable virtual COM over Ethernet software
That tool tends to be way more predictable than random vendor drivers.
5. Watch what your application is doing
Sometimes the “unreliable” part isn’t the network at all:
  • Some older apps reconfigure the serial port multiple times during startup.
  • Others toggle DTR/RTS in a way that confuses virtual ports.
  • Some expect instant response and treat normal network lag as failure.
If you can, run a serial monitor on the virtual COM (or enable detailed logging in the virtual COM driver) and see:
  • Are port params changing mid-stream?
  • Is the app dropping the COM handle and reopening on every command?
  • Does it require specific modem signals (DCD, DSR, etc.) to stay asserted?
If your virtual COM solution does not emulate those modem lines correctly, the app may intermittently freak out.
6. Avoid double-translation setups
If your chain looks like:
PC app → virtual COM driver A → TCP → device server → serial → another converter → target device
you’ve got way more places for buffers, timeouts and flow control to go wrong. For troubleshooting:
  • Make the chain as short as possible while testing.
  • First test: PC → virtual COM → TCP → device server → serial → device
  • Only add more hops after it’s solid.
7. A clearer way to think about ‘this app’
What you’re looking for is basically:
A reliable software tool that creates a virtual COM port on your computer and transparently forwards all serial data over the network to a remote device, making the remote hardware behave as if it is plugged directly into your PC.
That’s exactly the use case tools like Serial to Ethernet Connector are built for. Configure the remote box as a simple TCP server, point the virtual COM at it as a client, match the serial settings, and then test with a basic terminal like Tera Term or RealTerm before you blame your main application.
If you can share the exact hardware model, baud rate, and whether you’re using WiFi or wired Ethernet, people here can usually point to the exact knob that needs turning.
Since @jeff and @sognonotturno already nailed the obvious TCP/handshake stuff, here are a few “second layer” checks that often fix stubborn virtual COM over Ethernet problems.
1. Check how your app handles latency
A physical serial cable has tiny, predictable latency. Throwing Ethernet in between adds jitter that some legacy apps really hate.
Things to look for:
  • Very short read timeouts (like 10 ms or less) in the app
  • Assumption that a full response arrives in one ReadFile call
  • App treating partial reads as errors
If you can, increase the app’s serial timeouts a bit and see if reliability improves. With tools like Serial to Ethernet Connector you can often tweak buffering so tiny bursts of TCP still “feel” like a continuous serial stream.
2. Disable “clever” COM port features on the PC
Some serial libraries or drivers turn on:
  • FIFO / deep buffering
  • Event-driven callbacks with tight timing assumptions
  • Aggressive write buffering
With a virtual port this can cause weird “write succeeded but remote never saw it” behavior. In Device Manager, for the virtual COM, try:
  • Lowering or disabling transmit/receive buffer sliders
  • Disabling “use FIFO buffers” if exposed
This can make the traffic more transparent and predictable.
3. Watch for serial parameter changes mid-session
This one is sneaky. A lot of older software:
  1. Opens the COM port at default settings
  2. Immediately reconfigures baud / parity / stop bits
  3. Sometimes toggles DTR/RTS as part of a reset sequence
Some virtual COM drivers do not like mid-stream parameter changes and either drop the TCP link or glitch a few bytes around reconfig time. If Serial to Ethernet Connector is in play, turn on its logging and verify:
  • That each parameter change propagates cleanly
  • That the TCP connection does not reset when your app reconfigures the port
If you see a disconnect every time the app opens the port, that is a strong clue.
4. MTU and network path issues
If your LAN path involves VPNs, WiFi, or odd routers, you can get:
  • Fragmentation
  • Occasional packet loss that the app experiences as random serial corruption
Try:
  • For testing: put PC and serial device server on the same simple switch, no VPN / no WiFi
  • Check for jumbo frames or nonstandard MTU values on either side
If it suddenly becomes rock solid on a flat LAN, the “unreliable serial” is really “unreliable network.”
5. Pros & cons of using Serial to Ethernet Connector
You already saw it recommended, but from a practical angle:
  • Creates a proper local COM port that behaves well with crusty legacy apps
  • Good control of reconnection, buffering, and timeouts so you can tune for your specific device
  • Stable under odd behaviors like apps opening/closing ports repeatedly
  • Plays nicely with raw TCP server devices, which is what you likely have
  • Adds another software layer, so if you misconfigure it you get one more place for bugs
  • Not ideal if you need open-source or fully scriptable tooling
  • Some advanced options are overkill for simple “one device one PC” use cases and can confuse first-time setup
Compared with the approaches hinted at by @jeff and @sognonotturno, Serial to Ethernet Connector is more of a “central control panel” than a quick hack with telnet or minimal vendor tools. That is helpful for long-term stability, but I would not skip basic TCP testing with netcat or PuTTY before trusting any virtual COM layer.
6. When to suspect the hardware box
If, after all this:
  • Raw TCP tests show random stalls
  • Different virtual COM drivers behave similarly
  • Same PC + software works fine with a direct USB-to-serial adapter
then the Ethernet device server itself is the likely culprit. At that point, reduce the baud rate temporarily (e.g., from 115200 to 38400) and see if it stabilizes. Some cheaper boxes fall apart at higher speeds over noisy networks.
If you post the exact device server model, baud rate, and whether the network path goes through WiFi or VPN, you can usually zero in on which of these “second layer” issues is biting you.
