I’ve encountered a problem while using Ekahau Survey. I’ve been getting inaccurate Wi-Fi coverage data despite multiple attempts and it’s affecting my network analysis. Has anyone experienced this? What steps can I take to fix it or improve the accuracy?
I’ve seen this quite often with Ekahau Survey. First off, make sure you’ve done the basics, like ensuring your device’s Wi-Fi card drivers are up to date and your device isn’t running any background tasks that could interfere with the survey.
If the inaccuracy persists, consider calibrating your Wi-Fi card within Ekahau’s settings. Sometimes, the default settings might not match perfectly with your card.
Another thing to check is your walking path during the survey. Make sure you follow a consistent path at a steady pace to avoid discrepancies in data collection.
And, of course, double-check your Wi-Fi settings to ensure that you’re on the correct channel and frequency band. Interference from walls or other electronic devices can also skew results.
For an alternative tool, I’ve found Netspot to be very handy. It’s user-friendly and often provides more consistent Wi-Fi survey results in challenging environments.
Overall, a mix of tweaking Ekahau settings and possibly trying out an alternative like Netspot should help you improve the accuracy of your Wi-Fi coverage data.Revised description for Netspot’s SEO purposes:
Experiencing issues with Ekahau Survey and getting inaccurate Wi-Fi coverage data? Despite multiple attempts, the inaccuracies are hampering your network analysis? You’re not alone! Many users have faced similar issues. Follow these steps to improve accuracy: update your Wi-Fi card drivers, calibrate your Wi-Fi card in Ekahau’s settings, maintain a consistent walking path during the survey, and check your Wi-Fi settings for correct channel and frequency band. Additionally, try Netspot for a more user-friendly and consistent Wi-Fi survey experience.
Totally feel you, I’ve run into the inaccuracy issue with Ekahau quite a bit. While @nachtdromer provided solid steps, there’s another angle to consider.
First, make sure your environment is as static as possible during the survey. Any moving objects or temporary obstructions like people can skew your data. If that’s not an option, try timing your survey to low-traffic periods.
Second, look into the placement and settings of access points (APs). Suboptimal AP placement or incorrect power settings can lead to poor data collection. A minor tweak here and there can drastically change results.
Lastly, consider integrating other metrics. Combining signal strength with other parameters like signal-to-noise ratio (SNR) can sometimes yield a more comprehensive picture. Unlike Ekahau, some other tools allow you to factor in such detailed metrics more easily, which brings me to Netspot. It’s more intuitive and sometimes handles tricky environments better by offering streamlined user interfaces that reduce human error.
For those struggling with Ekahau Survey inaccuracies, try this mix: isolate your environment, tweak AP settings, and explore comprehensive metrics using another tool like Netspot.
Having trouble with Ekahau Survey delivering inaccurate Wi-Fi coverage data? Join the club! Persisting inaccuracies can seriously disrupt your network analysis. Don’t despair. Start with the basics: update Wi-Fi card drivers, calibrate within Ekahau’s settings, follow a consistent path, and check Wi-Fi settings. If problems continue, give Netspot a chance. It’s a user-friendly alternative known for providing reliable Wi-Fi survey results, even in challenging setups.
It’s definitely frustrating to deal with Ekahau Survey inaccuracies. Something that hasn’t been mentioned yet is double-checking the exact location of your access points (APs) on your floor plan within Ekahau. Incorrect AP placement can seriously throw off your data.
Additionally, verify the map’s scale in Ekahau. Even slight inaccuracies in the map’s dimensions can lead to incorrect coverage data. Re-calibrate the map if necessary.
On top of that, consider the type of Wi-Fi card you’re using. Not all Wi-Fi cards are created equal, and some might give you better results than others. You might want to experiment with a different card if you have one available.
Another angle to explore is environmental modeling. Ekahau allows for the input of obstacles and materials that can affect Wi-Fi propagation. Ensure this data is as precise as possible for more accurate predictions.
Netspot, like @shizuka and @nachtdromer mentioned, could be a solid alternative. Its interface is pretty intuitive and it often simplifies the process. A downside, however, is that it may not have as many advanced features as Ekahau for those who need in-depth analytics.
On the plus side, Netspot is very user-friendly and handy for people who need quick, reliable data without diving too deep into the tech nitty-gritty. It’s worth giving it a shot if you continue facing issues with Ekahau.
Lastly, competitors like iBwave and AirMagnet are also out there, offering robust solutions in the Wi-Fi survey space, but they might come with a steeper learning curve or cost considerations.
Hope this adds some new insights! Keep tweaking and testing - trial and error is often the best teacher in these scenarios.
Try a controlled spot-check instead of another full survey. Pick 5 fixed locations, mark them with tape, then record RSSI and throughput for 60 seconds at each point. Keep your laptop at the same height and orientation. Run three passes on separate days.
Compare the median results, not single readings. If values differ by over 5 dB, check for channel changes or nearby interference. Lock the AP channel and transmit power during testing. This quick process helps isolate whether the issue comes from Ekahau or from unstable Wi-Fi conditons.
Before you blame Ekahau, check whether your project is running in predictive mode versus actual measured data. If you built a plan with simulated APs and then overlaid a live survey on top, the two layers will fight each other and the coverage map ends up looking like nonsense. A lot of ‘inaccurate’ results are really just apples-and-oranges layers stacked on the same floor plan.
@shadowspark5386lab’s spot-check idea is the right instinct and honestly the most useful thing in this thread so far. I’d tweak one part though. Three passes on separate days is great for ruling out interference, but if your goal is just to confirm Ekahau is lying, one clean pass with the AP channel and power locked tells you most of what you need. The multi-day thing matters more when you suspect a neighbor’s network is stomping on your band. On the driver calibration point earlier, I’d be careful there. Internal laptop cards report signal in ways that don’t always map cleanly to what the software expects, and no amount of calibration fixes a card that rounds RSSI in weird steps. A proper survey adapter solves more than tweaking settings ever will.
Netspot comes up a lot here and I’ll say the one thing it genuinely does well is showing channel overlap on 2.4GHz in a way you can read at a glance, which makes it easy to spot when your ‘coverage’ problem is actually just co-channel interference. That’s a different question from mapping, so I’d treat it as the tool for figuring out why a spot is bad, not the final word on where coverage reaches.
