I just got a new Android phone and realized my voicemail isn’t set up, so callers can’t leave messages. I’ve tried looking through the phone and carrier settings but I’m not sure what I’m missing. Can someone walk me through how to properly set up voicemail on Android so I don’t lose important calls?
Happens a lot with new phones. Voicemail setup is split between your carrier and the Phone app, so it gets confusing fast. Here is a simple step by step that works on most Android phones in the US.
Find out your voicemail type
You either have:
• “Basic” voicemail where you dial a number and listen
• Visual Voicemail app from your carrier (Verizon, T‑Mobile, AT&T, etc.)Quick check
• Open the Phone app
• Tap the keypad
• Press and hold 1
If it calls voicemail, you have basic voicemail active. If you get an error like “voicemail not set up”, go to step 2. -
Set up voicemail with the carrier
This part is tied to your phone number, not the phone itself.Try this first
• Open Phone app
• Dial your carrier’s voicemail access number:
– Verizon: *86
– AT&T: hold 1 or dial your own number
– T‑Mobile: 123
– Google Fi: hold 1
• Call it
• Follow the voice prompts:
– Create a voicemail PIN
– Record your name
– Record a greeting (custom or default)If it says something like “voicemail box not found”, your line might not have voicemail enabled. Then you need to:
• Log in to your carrier account online or app
• Check your plan features and make sure voicemail is turned on
• Or call support and say: “Voicemail is not provisioned on my line. Please add standard voicemail.” -
Connect it inside Android
After voicemail is active at the carrier, Android needs the right number.• Open Phone app
• Tap the three dots in top right
• Settings
• Voicemail
• Voicemail number or Service
• Make sure it shows the correct voicemail access number:
– Verizon: *86
– AT&T: your own phone number
– T‑Mobile: +1‑805‑637‑7243 or 123 depending on region
• Save if neededThen:
• Go back to the keypad
• Press and hold 1 again
• It should take you into voicemail -
Turn on Visual Voicemail (optional)
If your carrier supports Visual Voicemail, you often get an app or a built‑in tab.Option A: In the Phone app
• Open Phone
• Look for a “Voicemail” tab at the bottom
• If it asks to set up or activate, follow the on‑screen promptsOption B: Separate carrier app
• Verizon: “Verizon Voicemail” or integrated in “My Verizon”
• T‑Mobile: “T‑Mobile Visual Voicemail”
• AT&T: “AT&T Visual Voicemail” or within Phone on newer phones
• Open the app
• Sign in if it asks
• Tap “Set up voicemail” or similar
• Grant permissions for phone and storage -
Check greeting and PIN again
Inside the voicemail system (by calling it):
• Press whatever key the menu says for “Personal Options” or “Mailbox Settings”
• Change PIN
• Change greeting
• Make sure greeting plays something and does not say “mailbox not set up” -
Test it
Use another phone if you have one, or ask a friend.• Call your new phone
• Do not answer
• Let it ring out
You want:
• It goes to voicemail
• Your greeting plays
• You can leave a message
• Then open Phone > Voicemail tab or Visual Voicemail app or call voicemail
• Confirm the message is there -
If it still fails
These are the main failure points:• Carrier voicemail feature missing
– Symptom: error like “mailbox not found”
– Fix: have carrier support add “Standard voicemail” or “Visual voicemail” to your line• Wrong voicemail number in settings
– Symptom: “number unreachable” or odd message in another language
– Fix: update voicemail number in Phone > Settings > Voicemail• Dual SIM confusion
– Symptom: phone uses the wrong SIM for voicemail
– Fix:
Phone > Settings > Calling accounts or SIM settings
Set the correct SIM as default for calls and voicemail• Wi‑Fi calling glitch
– Turn off Wi‑Fi calling in Network settings
– Try voicemail again over cellular only
If you post your carrier name and phone model, people here can give the exact menu paths and voicemail number for your setup.
What @shizuka wrote covers the “normal” setup really well, but a few weird edge cases can still block voicemail even if you followed those steps exactly. Here are the ones I run into a lot when people swap to a new Android:
Carrier “forgot” voicemail on your line
Even if you had voicemail working on your old phone, when you change SIM, port a number, or switch plans, carriers sometimes drop the voicemail feature silently.- Log in to your carrier account
- Look at your line’s add‑ons/features
- If you see something like “Basic Voicemail” or “Visual Voicemail” missing, that’s the problem
- Add it back (if it lets you) or contact support and literally say:
“Voicemail is not provisioned on my line, can you reprovision or reset my voicemail feature?”
Ask them to “reset the voicemail profile” if it’s “half working” (calls don’t forward, or mailbox full when it’s empty).
Call forwarding is hijacking voicemail
If calls never hit voicemail and just ring forever or fail, Android might have random call forwarding rules from your old setup.- Open Phone app
- Three dots > Settings > Calling accounts or Calls
- Look for Call forwarding
- Turn OFF any “Forward when busy / unreachable / unanswered” that point to some weird number
Then try again.
On some networks you can nuke all forwarding with a code from the dialer: - Dial ##004# or ##002# and press call (varies by carrier)
That resets forwarding to the default, which should send missed calls to voicemail.
Dual SIM weirdness
If your phone has two SIM slots or eSIM + physical:- Go to Settings > Network & Internet (or Connections)
- Make sure the correct SIM is set as default for calls
- In the Phone app > Settings > Voicemail, make sure you’re in the settings for the right SIM
Sometimes people set up voicemail on SIM 1 but are actually receiving calls on SIM 2.
Visual voicemail vs basic fighting each other
Sometimes the visual voicemail toggle makes things worse instead of better.
If you’ve turned on visual voicemail and it still shows “voicemail not set up”:- Turn OFF visual voicemail in the Phone app settings
- Power cycle your phone
- Call voicemail the old fashioned way (hold 1 or dial the carrier’s code)
- Complete the voice setup fully
After that, go back and re‑enable visual voicemail.
A lot of carriers will not let visual voicemail behave until the “classic” voicemail greeting and PIN are configured.
Samsung / Pixel / “OEM skin” menu shuffle
Not exactly disagreeing with @shizuka, but the menus can be annoyingly different depending on brand. For example:On Samsung:
- Phone app > three dots > Settings
- Supplementary services or Call forwarding may be under “Other call settings”
- Voicemail settings might be buried under “Voicemail” > “Voicemail settings”
On Google Pixel:
- Phone app > three dots > Settings > Voicemail
- There’s usually a “Visual voicemail” toggle and a “Advanced settings” link
Point is, if you cannot find the voicemail number at all, use the search in the main Settings app and type “voicemail”.
Check the voicemail ring time (optional but useful)
If callers say it rings forever then cuts, sometimes the timeout is broken or too long. Many carriers still use codes like:- 61*voicemail-number11*30# and Call
Where “30” is seconds (try 20 or 30). Carrier docs or support can confirm the exact format. Not strictly required, but it fixes “infinite ring then nothing” problems.
Last resort: full voicemail reset
If you’ve:- Confirmed voicemail feature is active
- Reset call forwarding
- Set the correct voicemail number
…and it still says “mailbox not set up” when people call, ask support to: - Delete your voicemail box
- Recreate a fresh voicemail mailbox
That will wipe old messages, but it often fixes stubborn issues after number ports or device changes.
If you share your carrier and phone model, people can probably tell you the exact voicemail access number and menu path. Right now you’re probably one carrier switch or forwarding reset away from it just working.
Couple of extra angles to try that weren’t really covered by @waldgeist or @shizuka:
Check if your number actually forwards to voicemail
They both focused on provisioning and basic setup, which is right, but sometimes the forwarding target on the network is wrong even if voicemail itself exists.- From the Phone app, dial:
*#67# and press Call
*#61# and press Call
Those usually show where “busy / no answer” calls are going. - If the number shown does not match your carrier’s voicemail access number (or is blank / error), contact support and ask them to “reset conditional call forwarding to voicemail.”
Confirm voicemail works from outside your phone
Instead of only holding 1, try:- Call your own number from a different phone
- When your greeting starts, press
*or#(varies by carrier) - Enter your PIN
If that works, then voicemail is fine and the problem is just Android’s shortcut / visual voicemail, not the mailbox itself.
Try a different dialer
Occasionally the manufacturer’s Phone app is buggy with certain carriers. Install “Google Phone” from Play Store, set it as default, then:- Open it
- Go to Settings > Voicemail
- See if it detects and configures voicemail correctly
If it works there, the issue is with the original dialer’s integration, not your carrier.
APN / network profile refresh
New phones sometimes carry old network settings from a restore.- Settings > Network & Internet > Mobile network
- Reset / restore default APN or “Reset network settings”
This will not delete data, but you will reenter Wi‑Fi passwords. After that, power cycle and test voicemail again.
If you recently ported your number
Ported numbers are the champions of “voicemail half works.” If that is your case:- Ask carrier support specifically to check “voicemail profile against the MSISDN after port completion”
In normal terms: make sure your new number is correctly tied to a mailbox on their system. Sometimes the old temp number’s mailbox is still attached.
On the “product” side, the built‑in Android Phone app essentially is your main voicemail client. It has pros like direct integration into call history and quick access from the keypad, but cons such as carrier‑specific bugs, inconsistent visual voicemail support, and differences between brands. Compared to what @waldgeist walks through (very carrier centric) and @shizuka’s more generic Android steps, relying only on the stock Phone app can be less transparent about what is actually failing behind the scenes.
If none of this flips it on, post your exact carrier + phone model. At that point it is usually a carrier‑side flag or forwarding table that needs a manual reset.
Your steps cover forwarding, mailbox access, dialer bugs, network profiles, and porting issues. Simpler route:
Do a clean Phone stack reset. Settings, Apps, Phone, Storage, Clear cache and Clear data. Repeat for Carrier Services. Reboot. Open Phone. Settings, Voicemail. Tap Reset to defualt for Voicemail number, or enter your carrier VM access number. Long press 1 to start setup. Test by calling your number from another phone. You should recieve the prompt and PIN setup within 2 to 3 minutes.
