Need help setting up Google Calendar from scratch
I’m trying to set up Google Calendar for the first time and I’m confused about how to create multiple calendars, share them with others, and sync everything across my phone and laptop. I’ve clicked around the settings but I’m worried I’ll miss something important like default reminders or time zone options. Can someone walk me through the right way to set up Google Calendar so it’s organized and easy to manage?
Here’s a simple way to get Google Calendar working the way you want.
  1. Create multiple calendars
  • On a laptop, go to calendar.google.com
  • On the left, find “Other calendars”
  • Click the + icon
  • Click “Create new calendar”
  • Give it a name, like “Work” or “Family”, pick a color
  • Repeat for each separate area of your life
    Now you will see checkboxes next to each calendar. Toggle them on/off to show or hide.
  1. Add events to the right calendar
    When you create an event:
  • Click a time slot
  • In the event popup, look for the Calendar field under the event title
  • Pick the calendar you want, like “Work” or “Personal”
    If you forget and it goes to the wrong one, open the event, change the calendar dropdown, hit Save.
  1. Share a calendar with other people
    Good for roommates, family, small teams.
  • On the left, hover over the calendar name
  • Click the three dots
  • Click “Settings and sharing”
  • Scroll to “Share with specific people or groups”
  • Add their email
  • Choose permission level:
    • “See only free/busy” if you do not want them to see titles
    • “See all event details” for normal sharing
    • “Make changes” if they should edit
  • Hit Send
    They get an email, then your calendar shows under “Other calendars” for them.
  1. Share a public calendar (optional)
    If you want a calendar for a club or public events:
  • Same “Settings and sharing” page
  • Find “Access permissions for events”
  • Check “Make available to public”
  • Pick if viewers see details or only free/busy
    Careful, public means anyone with the link or on web search can see it.
  1. Sync with your phone
On Android:
  • Open Settings app
  • Go to “Accounts” then pick your Google account
  • Make sure “Calendar” sync is on
  • Open the Google Calendar app
  • Tap the three lines at top left
  • Scroll down, make sure each calendar you want is checked/on
On iPhone:
Option 1, Google Calendar app
  • Install Google Calendar from the App Store
  • Sign in with your Google account
  • Open the side menu
  • Check the calendars you want visible
Option 2, iOS built‑in Calendar
  • Settings > Calendar > Accounts > Add Account > Google
  • Sign in
  • Turn on “Calendars”
  • Then open the iOS Calendar app and tap “Calendars” at the bottom
  • Enable the ones you want
If events are missing, force a sync:
  • On phone, in Calendar app, go to Settings
  • Tap your account, then “Sync” or “Sync all”
  • On desktop, refresh the browser
  1. Keep work and personal separate
    Simple setup that works well:
  • One calendar for “Personal”
  • One calendar for “Work”
  • Optional “Family” calendar shared with partner or kids
    Use different colors so your brain recognizes them quickly.
    Example:
  • Blue for work
  • Green for personal
  • Red for deadlines
  • Purple for shared family stuff
  1. Quick checks if things look broken
  • If you do not see a calendar on phone, confirm it is checked in the app menu
  • If you do not see new events on laptop, reload the page and check the checkboxes left side
  • If someone says they do not see your shared calendar, resend invite and check you used the right email
Once you get used to picking the calendar in the event popup, the rest becomes routine pretty fast.
Couple of extra tricks on top of what @reveurdenuit already laid out:
  1. Start by cleaning up the default chaos
    Google gives you one “Primary” calendar tied to your account. Before creating 10 new ones, rename that to “Personal” in Settings so you know what it is. A lot of people create another “Personal” and end up with two, then wonder why half their stuff isn’t on their phone.
  2. Avoid calendar overload
    Everyone loves “Work / Personal / Family / Fitness / Meal Plan / Dog’s Feelings” calendars. Most folks only actually use 2 or 3. I’d start with:
  • Personal (your default)
  • Work
  • Shared Family / Roommates
    If, after a week or two, you really feel like you need a separate one (e.g., “Side Hustle”), then add it. Too many calendars = you stop trusting what you’re looking at.
  1. Use reminders vs. calendars properly
    A lot of beginners create “Reminder” calendars or “Task” calendars, which gets messy. Use:
  • Events: things that happen at a specific time (meeting, dinner, gym class)
  • Tasks / Reminders: “Do laundry,” “Pay bill,” stuff you can do anytime that day
    In Google Calendar on the web, click the left side and enable “Tasks” if you want that. Don’t turn tasks into fake all day events unless you like visual clutter.
  1. For sharing, decide on one source of truth
    If you share with a partner / family:
  • Create one shared calendar called “Family”
  • Put only truly shared stuff there (kids’ activities, shared trips, appointments that affect both)
  • Keep your own personal things on your own Personal calendar, then just show it to them as free/busy if needed
    Big mistake I see: two people both sharing their full personal calendars and also using a Family calendar, then nobody remembers which one to use.
  1. Color strategy that actually works
    Slight disagreement with the suggestion to use lots of colors for each calendar. That works, but what usually works better long term is:
  • Use calendar-based colors for categories, not moods
  • Keep it consistent across devices
    If Work is blue on web but yellow on phone, your brain never adapts. Set the same color for each calendar on every device manually once.
  1. Phone sync sanity checks most ppl miss
    If stuff is not syncing:
  • Make sure the account is added on your phone, not just the app installed
  • In the Calendar app settings, check “Sync only events from last X days” is not limiting things if you want older events visible
  • Check if the event is on a calendar that is actually selected to sync, not just to show. On some Android builds those are separate toggles.
  1. Test everything with a fake week
    Before you trust it for real life, do a 5 minute test:
  • On laptop, create a “Test event 1” on Personal tomorrow at 9 AM
  • Create “Test event 2” on Work next week at 2 PM
  • Share one calendar with someone you know and confirm:
    • They can see what you expect
    • They cannot see what you don’t want them to see
  • Check your phone and verify both events show, with correct colors
  1. Privacy settings that can bite you later
    If you use “Make available to public” on any calendar, assume your boss / ex / random internet goblin can see it. If you need people outside your org to view it, use:
  • “Share with specific people” as much as possible
  • Public only for stuff that is truly okay on the open web, like club schedules
Once you get the structure right (few calendars, clear purpose, consistent colors), most of the confusion goes away. The actual clicking around is the easy part; deciding what goes where is what saves future-you from a calendar dumpster fire.
Couple of angles that haven’t been covered yet, focusing on how to actually live with your setup instead of just wiring it together.
1. Decide your “calendar rules” first
Before adding more calendars, write yourself 3 simple rules like:
  1. Work things that affect coworkers → “Work” calendar
  2. Anything that moves my body somewhere → “Personal”
  3. Anything that affects more than one person → shared calendar (Family / Roommates)
If you keep these rules, you will stop asking “which calendar should this go on?” every time. That is what actually keeps Google Calendar usable long term.
I slightly disagree with the idea of starting to share lots of stuff right away. Test your own system for a week first so you do not blast half-baked clutter to other people.
2. Use all‑day events vs timed events correctly
A common beginner trap: turning everything into all‑day events.
  • Use all‑day for: “Out of office,” travel days, birthdays, holidays, big deadlines.
  • Use timed events for: calls, appointments, study blocks, anything where being late matters.
Then your week view becomes a clear visual map: all‑day strip at the top for context, time grid for what you actually do.
3. Learn 3 views and ignore the rest
To avoid feeling lost, stick to:
  • Week view as your default on laptop
  • Schedule / Agenda view on phone for quick scroll
  • Month view only when planning vacations or big picture stuff
Switching views constantly is confusing when you are new. Lock these in until the app feels natural.
4. Use notifications in a sane way
Most people either get spammed by alerts or miss everything.
Try this:
  • Default notification: 10 minutes before event
  • For important stuff: add a second reminder (e.g., 1 day before)
  • Turn off email notifications for regular events so you are not drowning in inbox noise.
Go into each calendar’s own notification settings and tweak. For shared calendars you might want fewer pings.
5. Quick mobile workflow that keeps desktop & phone in sync
Instead of fiddling with settings all the time, use this daily pattern:
  • On your phone:
    • Capture events quickly as they come up. Do not worry if they land on the wrong calendar sometimes.
  • On your laptop once a day:
    • Open “Schedule” or “Week” view.
    • Spend 2 minutes cleaning things: move events to the correct calendar, adjust times, delete junk.
That small daily cleanup fixes 90 percent of sync confusion and keeps everything consistent across phone and laptop.
6. When sharing, protect yourself from accidental over‑sharing
For any calendar you share:
  • Turn off “Make available to public” unless it is truly meant to be public.
  • For work or acquaintances, use “See only free/busy” if you just want them to know you are not free.
  • Reserve “Make changes and manage sharing” only for people you absolutely trust to not wreck your stuff.
Do a quick test: make a fake event called “Test: can you read this?” and confirm what others can or cannot see. That 30‑second check avoids embarrassing surprises later.
7. Comparing approaches
  • What @nachtschatten gave you is great for structure and avoiding chaos once multiple people are involved.
  • What @reveurdenuit added is super practical on the “don’t make 10 calendars you never use” side.
If you blend their advice with a few personal rules, you will end up with a simple, durable system: 2–3 calendars, clear purpose for each, predictable colors, and no mystery events lurking in the wrong place.
Pros & cons of this kind of Google Calendar setup
  • Clear separation of work / personal / shared without needing complicated tools
  • Easy to see who is involved with what at a glance
  • Scales nicely if your life gets busier over time
  • Requires a bit of discipline at first to always pick the right calendar
  • Too many shared calendars can still get noisy if others are messy
  • If you rely only on phone, some finer settings are easier to miss without occasionally checking on a laptop
