Need help fixing issues with the HP Smart app on my computer
I’m having trouble getting the HP Smart app to work properly with my printer. It keeps failing to connect and sometimes won’t detect the printer at all, even though they’re on the same Wi-Fi network. I’ve already tried reinstalling the app and restarting everything, but nothing has helped. I need step-by-step guidance to troubleshoot the HP Smart app, fix the connection issues, and make sure printing and scanning work reliably.
HP Smart on Windows acts weird a lot, so you’re not the only one fighting it. Here is what usually fixes the “same Wi Fi but no printer” mess.
  1. Forget HP Smart for a second
    • Uninstall HP Smart from your PC.
    • Download and run “HP Smart and Scan Doctor” or “HP Print and Scan Doctor” from HP’s site.
    • Let it scan, fix ports, and reset the printing system.
  2. Check the printer’s network status
    • On the printer panel, print a Network Configuration or Wireless Test report.
    • Look at:
    • IP address, something like 192.168.1.x
    • Status: Connected
      • On your PC, run:
    • Windows key + R
    • Type cmd, press Enter
    • Type: ping 192.168.1.x (replace with the printer IP)
      • If ping fails, then they are not on the same subnet or the router blocks discovery.
  3. Lock in a fixed IP
    HP Smart often loses printers with changing DHCP IPs.
    • Go to your router’s web page.
    • Add a DHCP reservation for the printer’s MAC so it always gets the same IP.
    • Or set a manual IP on the printer inside the same range.
    • Then on Windows, add it by IP:
    • Settings → Bluetooth & devices → Printers & scanners → Add device → “The printer I want isn’t listed” → “Add a printer using a TCP/IP address” → Use the printer’s IP.
  4. Disable junk that blocks discovery
    • Temporarily turn off VPN on your PC. VPNs break local discovery often.
    • Turn off “Public” network profile.
    • Settings → Network & Internet → Wi Fi → Click your network → Set it to Private.
      • In Windows Defender Firewall, allow HP Smart and HP network services through.
      • If you run a third party firewall, pause it and test.
  5. Reset printer network
    Sometimes the printer gets stuck.
    • On the printer, run “Restore Network Settings” or “Reset Wireless Settings”.
    • Reconnect it to Wi Fi from the printer screen, not from HP Smart.
    • Once it has an IP and shows “Connected”, then open HP Smart and click “Set up a new printer”.
  6. Kill old HP drivers
    Old drivers or half installs mess stuff up.
    • Control Panel → Programs → Programs and Features.
    • Remove anything HP printing related.
    • Reboot the PC.
    • Download the “Full feature software and drivers” for your exact model from HP’s support page.
    • Install that first, then install HP Smart from Microsoft Store.
  7. Check router settings
    Look for:
    • AP Isolation / Client Isolation → turn off.
    • Separate 2.4 GHz and 5 GHz SSIDs. Printers often prefer 2.4 GHz. Keep your PC on the same band during testing.
    • Multicast or IGMP snooping options. If multicast is blocked, HP Smart will not see the printer by name.
  8. Quick test without HP Smart
    If Windows prints by IP but HP Smart still does not see the printer, then:
    • The driver and network path are fine.
    • HP Smart is the problem. Use the older HP full driver app for scanning and status, or the printer’s web page (type the printer IP in a browser) for maintenance.
Try in this order for least pain:
  1. Reset network on printer and reconnect to Wi Fi.
  2. Ping the printer IP.
  3. Add the printer by IP in Windows.
  4. Reinstall HP Smart only after the printer works through normal Windows printing.
If you share exact printer model, router model, Windows version, and if ping works or not, it gets easier to narrow the next step.
Couple of extra angles you can try that are a bit different from what @waldgeist suggested:
  1. Skip HP Smart “auto discovery” entirely
    HP Smart loves to “search” forever and then fail. Instead:
    • Open HP Smart
    • Hit “Add printer”
    • Look for any tiny “Set up using IP address” / “Add manually” text link (HP hides it like it’s a cheat code)
    • Type the printer’s IP directly
      That often works even when the normal discovery list is empty.
  2. Verify Windows can actually talk WSD / mDNS
    HP Smart leans heavily on Windows network discovery protocols. If those are borked, Smart freaks out even if the printer responds to ping.
    • In Windows features:
      • Turn on “SMB 1.0/CIFS File Sharing Support” temporarily if it’s off, just for testing.
      • Make sure “Network Discovery” and “File and Printer Sharing” are enabled in Advanced sharing settings.
    • After that, reboot and see if HP Smart suddenly finds it.
      (Yeah, it’s dumb that a printing app cares about file sharing settings, but here we are.)
  3. Kill HP account sync weirdness
    Sometimes the HP account itself gets stuck.
    • Sign out of HP Smart (top-right account icon)
    • Close the app
    • In %AppData%\HP and %LocalAppData%\Packages, remove HP Smart caches/folders related to “HPInc.PrintStudio” or similar
    • Open HP Smart again, sign in fresh, then “Set up a new printer”
      I’ve watched this alone fix a “same Wi Fi, no printer” situation.
  4. Avoid “Wi-Fi Direct” confusion
    Make sure you are not accidentally on the printer’s Wi-Fi Direct network instead of your home Wi-Fi. If your PC ever joined something like DIRECT-xx-HP-..., Windows can cling to it.
    • Forget that network in Wi-Fi settings
    • Reconnect to your real router SSID
    • Then retry HP Smart
      The printer should be on the router, not broadcasting its own network for normal home use.
  5. Try USB first, then convert to network
    I actually disagree slightly with jumping straight to all the network voodoo. HP’s installer behaves way better when it sees a USB printer initially.
    • Connect the printer via USB
    • Launch HP Smart, let it fully detect and finish setup
    • In HP Smart, run “Convert to wireless” or similar wizard
    • Once Wi-Fi is configured and it shows the network IP, then unplug USB
      This often stabilizes the config, especially on newer HP models.
  6. Check if Windows is silently using a “WSD” port that’s flakey
    Even if printing works sometimes but Smart fails, the port type might be the issue.
    • Click your printer → Printer properties → Ports tab
    • If it says WSD-..., add a Standard TCP/IP Port instead using the printer’s IP
    • After that, reopen HP Smart and see if anything improves
      WSD is notorious for randomly dropping devices on some routers.
  7. Test from another device to isolate the culprit
    If you haven’t already:
    • Install HP Smart on a phone or tablet on the same Wi-Fi
    • See if it sees the printer instantly
    • If phone finds it but the PC does not, the problem is Windows / HP Smart for Windows, not the printer or router.
      In that case, a full HP Smart reset + clearing HP folders + new Windows user profile sometimes is faster than endless tweaking.
If you can post your exact printer model, Windows version, and whether HP Smart on a phone works, it’s a lot easier to say “this is 99% a Windows side problem” vs “router/printer issue.”
For a simpler workaround, try adding your printer through Windows instead of HP Smart.
On Windows 11, open Settings > Bluetooth & devices > Printers & scanners. Select Add device, choose your printer, and follow the prompts. No manual IP address or port changes needed for this attempt.
Then open a doc, press Ctrl+P, select your printer, and try printing. If it works, leave HP Smart closed for everyday printng. This sidesteps the app rather than fixing it, but gets your work moving if Windows detects the printer.
Test it from your phone before touching any Windows settings. If HP Smart on the phone finds the printer instantly, stop chasing the router and the firewall stuff from above, your printer and network are fine and it’s purely the PC side. Saves you an hour of poking at IP reservations that were never the problem.
