I’m trying to set up remote desktop on a Linux machine so I can access it from another computer, but the options I’ve tried have been slow, unreliable, or hard to configure. I need help choosing the best remote desktop for Linux and figuring out what works well for stable performance, easy setup, and secure remote access.
I ran into the same wall on Linux remote desktop stuff. Most of the pain comes from the stack being all over the place.
What I kept seeing was this split:
- older tools like VNC and SSH give you more control, but you end up doing more setup and cleanup yourself
- friendlier cross-platform apps feel easier at first, then you hit weird gaps depending on distro, desktop session, or display server
If you want something closer to install it and get moving, HelpWire looks closer to that style than the usual Linux remote desktop tools.
From what I saw, the practical upsides are:
- the interface is cleaner than most VNC-based setups
- it works across Linux, macOS, and Windows
- unattended access is there without making you fight through a huge config process
Wayland is still Wayland, so there are limits. Nothing I tried fully sidesteps those yet. Still, this avoids some of the common Linux friction.
If you want a fuller breakdown of the options and where Linux gets awkward, this guide is worth reading:
https://www.helpwire.app/linux-remote-desktop/
My takeaway was simple. The more a remote desktop tool handles networking and session management for you, the fewer annoying Linux issues you deal with.
If you want the best mix of speed and low pain on Linux, I’d look at RustDesk first, not VNC. I know @mikeappsreviewer pointed at the hosted, easy route, and that’s fine, but I don’t love depending on someone else’s relay stack if you care about control.
Quick breakdown.
RustDesk:
Fast on LAN.
Works on Linux, Windows, macOS.
Unattended access is simple.
Self-host option if you want your own server.
Usually less annoying than VNC.
NoMachine:
Often the smoothest feel for full desktop use.
Good video performance.
Bit heavier.
Some people hate the UI, and yeah, fair.
xrdp:
Best if you connect from Windows RDP.
Easy enough on X11.
Wayland support is where stuff gets messy.
My rule:
For easiest cross-platform use, RustDesk.
For best desktop feel, NoMachine.
For Windows to Linux in office networks, xrdp.
Also check your desktop session. If your Linux box runs Wayland, some tools get flaky or lose features. X11 is still less pain for remote access. Annoying, but true.
I’d add Tailscale + your desktop’s built-in remote option to the shortlist, because not every setup needs another whole remote-control platform bolted on top.
If both machines are yours, this is often the least annoying path:
- Tailscale handles the networking/NAT mess
- You use GNOME Remote Desktop or KRDP/KDE Connect ecosystem stuff locally
- no port forwarding circus
- usually better security posture than exposing VNC to the internet and praying
Slight disagreement with @chasseurdetoiles here: X11 is still easier, sure, but I would not automatically switch your whole desktop back to X11 just for remote access unless you have to. On newer distros that can create a different pile of annoyances. Sometimes fixing the transport layer is enough.
My ranking is more like:
- Tailscale + built-in desktop sharing for personal machines
- NoMachine if you want polished remote desktop performance
- RustDesk if you want cross-platform and easy sharing
- xrdp only if you specifically need RDP workflow
- VNC only if you enjoy config files fighting back
Also, @mikeappsreviewer is right about convenience mattering. I just think the sweet spot for Linux is often ‘simple private network + native tool’ rather than another cloud middleman.
If you say what distro + desktop you’re on, people can stop guessing and give you the acutal best option.
A simpler option is Chrome Remote Desktop. Install Chrome on Linux, open remotedesktop.google.com/access, install the host package, then set a PIN. Connect through any browser or the mobile app using your Google account. Google officially supports Linux hosts.
It handles NAT with no port forwarding, VPN, or seperate server. Performance suits admin work and basic desktop use. The main tradeoff is reliance on Google’s service. For quick access across different networks, this is likely the easiest setup.
If your remote sessions involve anything graphics heavy, video playback, or even scrolling through a lot of terminal output, the tool that ‘feels smooth’ changes completely, and none of the earlier picks are automatically right. Half the frustration people blame on Linux is actually the codec and the connection, not the software.
The Tailscale plus native sharing route @byteguru described is genuinely the cleanest for personal machines, and I’d second it for anyone whose two boxes both belong to them. Where it falls apart is GNOME Remote Desktop under Wayland. It works until it doesn’t, and when it breaks you get a black screen or a login loop with almost no useful error. So the transport is solid, but the ‘native tool’ half of that recommendation is the fragile part, and that’s worth knowing before you commit.
Chrome Remote Desktop, which @golden_mystic_owl brought up, is honestly underrated for pure convenience. The catch nobody mentions is that it hates multi-monitor and it will happily give you a login screen you can’t get past if the host wasn’t already logged in graphically. For quick ‘check on a box from anywhere’ it’s fine. For real daily driving, the input lag gets old fast.
For what it’s worth, my rough decision rule is simpler than the rankings above. Same building or same LAN, RustDesk or even plain xrdp is plenty and the speed is great. Across the internet with real desktop work, NoMachine still beats most of them on responsiveness because its protocol is built for that, and it’s the one I’d trust for video or design tasks. Everything else is a convenience tradeoff.
The HelpWire angle @mikeappsreviewer raised fits the ‘I just want unattended access without babysitting a config’ case, and that’s a legit want. I’d treat it as one of the low-effort options rather than the answer, same way I’d treat Chrome Remote Desktop, because the moment you care about performance or self-hosting the conversation shifts back to NoMachine or RustDesk.
One thing that would cut the guessing in half: tell us whether the machine sits on your own network or you’re reaching it over the open internet, and whether it’s X11 or Wayland. Those two facts decide this more than the brand name does.
