Need help figuring out how to use Google Drive on my Mac
I’m trying to set up and use Google Drive on my Mac but I’m confused about the best way to install it and sync my files. I’m not sure if I should use the web version, download the Drive app, or both, and I don’t want to mess up my existing folders or lose anything. Can someone walk me through the right way to use Google Drive on macOS and keep everything properly synced and backed up?
Using Google Drive On A Mac Without Losing Your Mind (Or Your Disk Space)
So, if you’ve ever tried to use Google Drive on a Mac the “normal” way, you already know the deal: install Google’s app, wait for it to sync a giant folder, watch your free disk space evaporate, then start frantically deciding what to keep offline and what not to. It works, but it feels clunky, especially if you juggle multiple Google accounts.
Here’s how I ended up doing it differently and basically treating Google Drive like an extra hard drive that just lives in Finder.
The Basic Idea: Treat Google Drive Like Another Disk
On macOS, you’re used to seeing stuff in Finder under “Locations”: your Mac’s SSD, maybe an external drive, maybe a network share.
The thing that changed the game for me was using an app that lets Google Drive show up there, as if it were a local disk, but without actually syncing everything to your Mac. You click, the folder opens, and the files stream on demand.
That app is CloudMounter.
What it does for Google Drive on Mac:
  • Mounts Google Drive so it shows up in Finder like an external drive
  • Lets you work with files without downloading everything to local storage
  • Handles multiple Google Drive accounts without weird browser gymnastics
  • Basically makes cloud storage feel native to macOS
No marketing fluff here, just how it behaves in real use.
Why I Started Using It Instead Of The Usual Google Drive App
Short version: storage and sanity.
  • My internal SSD is small. If I sync everything, it fills up fast.
  • I have more than one Google Drive account (personal, work, one for shared stuff).
  • Switching between accounts in Google’s tools is annoying, especially if you want them all available at once in Finder.
With CloudMounter, you don’t have to sync the entire cloud folder to your Mac. You just mount it and browse. Files only take up real local space if you open or copy them. It feels like you’re just browsing a normal drive in Finder, without the giant “Google Drive” folder eating your disk.
How To Use Google Drive On Mac With CloudMounter
Here’s the simple, step by step version, no tech jargon:
  1. Install and open CloudMounter
  2. Pick Google Drive from the list
    • Inside CloudMounter you’ll see icons for different services (Dropbox, OneDrive, etc.).
    • Click the Google Drive icon.
  3. Sign in to your Google account
    • A Google login window will pop up.
    • Log in with your usual Google email and password.
    • When Google asks if you want to allow access, click Allow so CloudMounter can see your files.
  4. Mount the drive
    • After logging in, you’ll see a “Mount” button in CloudMounter.
    • Click Mount.
    • Your Google Drive will now appear in Finder under Locations, like a drive or external disk.
  5. Use it like a normal folder in Finder
    • Open Finder.
    • Find your Google Drive in the sidebar under Locations.
    • Double click it.
    • Now you can:
      • Open files
      • Edit documents
      • Drag files in and out
      • Create folders
    • It feels like working with a local folder, but you are actually working directly in the cloud. No full sync required.
What It Feels Like In Daily Use
You open Finder, click your Google Drive, and forget that it is not physically on your Mac. That’s basically it.
  • Need to upload a big folder? Just drag it in Finder to your mounted Drive.
  • Need to grab something from Drive for a project? Open it directly, no web browser, no download step.
  • Working across multiple Google accounts? Mount each one separately and name them clearly, then switch in Finder like you would between drives.
The main win is that your Mac’s storage stops being held hostage by synced cloud files. You just stop thinking about “sync status” and use it like storage that happens to live on the internet.
Using Multiple Google Drive Accounts
If you run more than one Google account, here is how it helps:
  1. Add your first Google Drive account in CloudMounter and mount it.
  2. Repeat the process for your second (or third) Google account:
    • Click Google Drive again inside CloudMounter
    • Sign in with a different Google login
    • Click Mount
  3. In Finder, you will see separate entries for each account, and you can rename them in CloudMounter so they show up as “Work Drive”, “Personal Drive”, etc.
No more signing in and out in the browser or trying to remember which account is currently “active” in Google’s own Drive tools.
Why This Saves Disk Space
When you use it like this:
  • Files stay in Google’s cloud by default.
  • Your Mac only deals with files you are actually using.
  • You avoid keeping a complete mirrored copy of your whole Drive on your local disk.
So if your Google Drive is, say, 500 GB but your Mac only has a 256 GB SSD, this setup actually makes sense. You can still see and access everything in Finder, but your internal storage is not trying to match that size.
Quick Recap
  • You can use Google Drive on Mac through Finder without syncing all files locally.
  • CloudMounter mounts Google Drive as if it were another drive in Finder.
  • Setup is: open app → click Google Drive → sign in → click Mount.
  • After that, you open, edit, and move files straight in Finder like they are local.
  • It works well if you want to save disk space and manage multiple Google Drive accounts easily.
Short version: you probably want both the web and a desktop approach, but not necessarily Google’s own sync app for everything.
@​mikeappsreviewer already covered the CloudMounter angle really well, so I’ll go a bit different route and compare the main options and how you might mix them.
1. Web version of Google Drive
Use this for:
  • Quick uploads / downloads from a browser
  • Sharing links, managing permissions
  • Using Google Docs/Sheets/Slides in their native habitat
  • Nothing to install
  • No disk space drama
  • Always up to date
  • Feels clunky for serious file management
  • Drag/drop big folders is slower and more fragile
  • No offline access unless you set up offline mode in Chrome for Docs/Sheets only
You should keep using the web version regardless of what else you do. It’s the control center.
2. Official “Google Drive for desktop” app
This is where people get confused. Google quietly changed it: it doesn’t have to sync everything locally anymore.
It has two main modes:
  1. Stream files
    • Files live in the cloud
    • They show up in Finder as a mounted drive
    • Files download on demand
    • You can mark specific files/folders “Available offline”
  2. Mirror files
    • Keeps a full copy of Drive on your Mac
    • Eats disk space like crazy
    • Only makes sense if you need full offline access to everything
If you install Google Drive for desktop, pick “Stream files” during setup. That gives you a Google Drive entry in Finder that behaves a bit like what CloudMounter does, but only for Google Drive and with Google’s own quirks.
  • Free
  • Officially supported by Google
  • Integrated with Google Docs (double‑click a .gdoc opens it in browser)
  • Multiple accounts are annoying
  • UI is kinda clunky
  • Still possible to accidentally flip into mirroring and nuke your disk space
I slightly disagree with relying only on CloudMounter like @​mikeappsreviewer suggests. For some people, the official Google Drive app is fine if you configure it correctly and only use “Stream.”
3. CloudMounter approach
Where CloudMounter is genuinely nice:
  • You can mount multiple Google Drive accounts at once and see them separately in Finder
  • Nothing gets fully synced unless you actually work with it
  • Same app also handles Dropbox, OneDrive, etc., so your cloud stuff is all in one place
If your main worries are:
  • Small SSD
  • Several Google accounts
  • Want everything to look native in Finder
then CloudMounter is worth using as your “daily driver” for storage. It’s basically like turning Google Drive into a network drive. And yeah, it’s pretty SEO‑friendly to say “CloudMounter for Google Drive on Mac” because that’s literally what people google when they’re tired of the official app misbehaving.
One caveat: if your internet is slow or flaky, streaming everything through CloudMounter (or Google Drive streaming) can feel laggy. In that case, selectively syncing key folders offline with Google’s own app can still make sense.
4. So what should you do?
If I were setting this up fresh on a Mac:
  1. Always use the web for:
    • Sharing, permissions, quick edits in Docs/Sheets
  2. Install Google Drive for desktop but:
    • Choose “Stream files” only
    • Mark just a few critical folders “Available offline”
  3. If you have multiple accounts or several cloud services:
    • Add CloudMounter
    • Mount your personal / work / shared Drives separately
    • Use Finder as your hub, with CloudMounter handling the accounts
That mix gives you:
  • Web for control
  • Official app for a bit of offline and Docs integration
  • CloudMounter for clean Finder access and multiple accounts without losing your mind (or your SSD).
If you say how big your Drive is and how much free space you have on the Mac, it’s possible to get even more specific on whether to rely more on streaming vs some selective offline folders.
Short version: use more than one option, but for different jobs, so they don’t trip over each other.
What @mikeappsreviewer and @cazadordeestrellas said about CloudMounter and Google’s “Stream files” mode is solid. I’d tweak the strategy a bit so you don’t end up with weird duplicates or mystery space usage.
Here’s how I’d set it up on a Mac from scratch:
  1. Keep the web version no matter what
    Use drive.google.com for:
    • Sharing / permissions
    • Quick checks when something looks weird in Finder
    • Managing trash and storage
      The web UI is clunky for big file moves, but it’s the “source of truth.”
  2. Install Google Drive for desktop, but only for what needs reliable offline
    Where I slightly disagree with both is: I would not stream your entire Drive with Google’s app if you’re already using something like CloudMounter. That’s how you get confusion and duplicated caches.
    Instead:
    • During setup, choose Stream files
    • Then only mark 1 or 2 “core” folders as Available offline
      Use this for stuff you absolutely need even if your wifi dies. Think “Documents I open every day,” not your whole archive of 2013 vacation photos.
  3. Use CloudMounter as your main Finder view of Google Drive
    If you:
    • Have multiple Google accounts, or
    • Have a small SSD, or
    • Hate that random hidden Google Drive folder it creates
    then CloudMounter is the cleaner primary interface.
    Specific use:
    • Mount all your Google Drives with CloudMounter
    • Use the CloudMounter Google Drive mounts for everyday browsing in Finder
    • Treat them like network drives: always visible, nothing fully synced unless you copy it locally
      This way, CloudMounter for Google Drive on Mac becomes your “everything view,” and Google’s own app is just your little offline helper.
  4. Avoid these two easy mistakes
    • Don’t: let Google Drive switch you to “Mirror” mode. That’s the nuclear option for disk space. If you ever see it talking about “mirroring,” back out.
    • Don’t: start dragging stuff between the CloudMounter mount and the Google Drive desktop folder without paying attention. It can work, but it’s very easy to accidentally duplicate gigabytes of data.
  5. Pick a simple mental model so you don’t go nuts
    Something like:
    • “Web = admin & sharing”
    • “CloudMounter = everything in Finder, uses cloud space, not disk space”
    • “Google Drive app = small set of folders I need when I’m offline”
If you share how big your Google Drive is and how much free disk space is on your Mac, you can dial this in a bit more, but this combo keeps things predictable without the sync circus.
Short version: think in “layers” instead of “which single app do I use.”
1. Web, native Google Drive app, or CloudMounter: when to use which
  • **Web **
    Best for: sharing, permissions, Trash, and when Finder views look suspicious.
    You should always keep this in your toolkit, like others already suggested.
  • Google Drive for desktop (Google’s own app)
    Best for: a small set of folders you need offline and for apps that need a “real” local folder.
    I disagree slightly with relying on it as the main interface. Even in “Stream files” mode it still builds cache and can chew space over time, especially if you open a lot of big files.
  • CloudMounter
    Best for: treating Drive like a mounted network disk that does not live on your SSD. This is what @cazadordeestrellas, @stellacadente and @mikeappsreviewer were circling around, but I’d lean even harder into it if you are low on storage or juggling several accounts.
2. Pros and cons of CloudMounter in this mix
  • Shows Google Drive in Finder under Locations as if it were an external disk
  • Very little local space used because it streams files on demand
  • Handles multiple Google accounts at once without browser account switching
  • Keeps your main drive uncluttered since you are not forced into a giant “Google Drive” folder
  • Needs an internet connection for almost everything, since there is no deep offline mirror
  • Adds another app into your setup, so there is one more place where something can be misconfigured
  • Not ideal if you constantly edit huge media files and expect local‑disk speeds
3. How I’d actually set you up (keeping it simple)
  1. Keep using the web for admin stuff and odd edge cases.
  2. Use CloudMounter as your primary “view” of Google Drive inside Finder. Just open Finder and treat it like a mounted storage volume.
  3. Install Google Drive for desktop, but only:
  • Turn on Stream files
  • Mark just a couple of key folders as Available offline
    That gives you a safety net when the internet is spotty without turning your Mac into a clone of your whole Drive.
Compared with what @cazadordeestrellas, @stellacadente and @mikeappsreviewer suggested, the main twist here is: don’t let Google’s app be the boss. Let CloudMounter be the main Finder integration, and keep Google Drive for desktop as a lightweight offline helper instead of the primary sync engine.
Try a backup focused setup.
Skip Finder mounts. Use Drive on the web for browsing and sharing. Install Google Drive for desktop, open Preferenes, disable My Drive. Enable My Computer, pick Desktop and Documents. Choose Upload only. No mirror. A 200 GB Drive stays in cloud, your 256 GB SSD stays free.
Turn on Google Docs offine in Chrome for one Offline folder. Zip big folders before upload, fewer failures. Create a Drive folder named Transfer for quick drops from teh Downloads. This feels simple, uses little disk, and survives flaky wifi.
