I ordered a Ryoko Wifi device for an upcoming trip after seeing ads promising easy portable internet everywhere, but shipping is delayed and I’m reading mixed reviews. Some say it barely works or has hidden fees. Can anyone share real experiences, performance, and costs, and suggest better portable wifi options if this one isn’t trustworthy
Short answer from someone who learned the hard way on this one.
Ryoko WiFi is not an outright scam in the sense of “you get nothing”, but it is heavily overhyped and often poor value for travel.
Here is what I ran into and what others report a lot:
- Shipping and support
- Long shipping times, especially before trips.
- Weak customer support, slow replies, template answers.
- Refunds take time and some users get bounced around.
- Performance and coverage
- It uses existing 4G networks. No magic global signal. If the local carrier is weak, Ryoko is weak.
- In big cities in Europe I saw ok speeds for email and maps. Streaming was hit or miss.
- In rural areas it often dropped or got stuck at like 1–2 Mbps.
- A regular local SIM in an unlocked phone or hotspot worked better in the same spots.
- Hidden costs and data limits
- The ads make it sound like “internet everywhere” for one flat price.
- In reality you buy data packages, and they are not cheap per GB.
- Some users get surprised by how fast the “fair usage” limits kick in.
- For heavy use, an eSIM or local SIM almost always costs less.
- Where it might work for you
- Light use: maps, WhatsApp, email, flight check‑ins.
- If you are not comfortable messing with local SIMs.
- If you move between several countries in a short time and want one device, even if it costs more.
- Better options for travel
- eSIMs like Airalo, Nomad, Holafly, etc. You install an eSIM profile and buy data per country or region. Cheaper per GB in most cases.
- Local prepaid SIMs from airport kiosks or phone shops. Best price and often best speed, if your phone is unlocked.
- Your phone as a hotspot, instead of a separate gadget, if your plan supports roaming at a sane rate.
- Checking what will work where you go
Before you buy more data for Ryoko or any hotspot, check which carriers operate in your destination and what frequencies they use. If you want to get a bit more serious, tools like advanced WiFi troubleshooting and analysis help test WiFi quality on laptops and help you understand if the issue is the hotspot, the local network, or your environment. It is more for home and office, but I used it in hotels to see if the hotel WiFi was fine and my hotspot was the weak link.
What I would do in your place
- If your trip is soon and shipping is delayed, start a support ticket now and ask for a clear shipping date. If they do not give you one, push for a refund before you travel.
- For the trip, grab an eSIM for your destination and use your phone hotspot.
- Keep the Ryoko as a backup only if you are inside any return period. Test it at home first, and stream something, use maps, run a couple of speedtests.
If you expect it to give you strong, cheap internet “everywhere”, you will be dissapointed. If you treat it as a convenience gadget for light use, it is ok but overpriced.
I wouldn’t call Ryoko WiFi a straight-up scam, but it sits in that annoying gray zone of “overmarketed gadget that often disappoints.”
Your situation (delayed shipping, mixed reviews, worry about hidden fees) is basically the classic Ryoko story.
Here’s how I’d break it down, trying not to just repeat what @vrijheidsvogel already laid out:
1. Reliability for actual travel use
- It’s just a 4G hotspot that connects to local carriers. No special satellite magic, no “internet everywhere” miracle.
- If local 4G is strong, Ryoko can be fine for light use: maps, messaging, email, basic browsing.
- If you’re in rural areas, inside thick buildings, or somewhere with mediocre coverage, expect dropouts and slow speeds.
- It does not replace a solid local SIM or eSIM in terms of consistency or price.
2. The whole “hidden fees” / pricing issue
Where I slightly disagree with @vrijheidsvogel is that I don’t think the pricing is mysterious so much as it is misleading by omission:
- The marketing makes it sound like you buy a device and boom, cheap internet nearly everywhere.
- In reality you’re buying:
- The device
- Separate data packages, often more expensive per GB than local options
- If you stream, upload photos, use social media a lot, the “fair use” caps hit very fast, and then it feels like you got tricked.
So: not criminal, but definitely “read-the-fine-print-or-regret-it” territory.
3. Shipping delays & what to do right now
If your trip is soon and it still hasn’t shipped:
- Hit support now and ask for a firm ship date.
- If they can’t give a clear answer, I’d lean toward canceling and getting a refund before you leave.
- Don’t rely on it as your primary internet plan unless you have it in hand and tested.
4. Realistic way to use it (if you keep it)
If it arrives in time:
- Test it at home:
- Run a few speed tests.
- Try watching YouTube or Netflix.
- Walk around your area and see how often it drops.
- Treat it as:
- A backup hotspot for light tasks
- A simple solution if you hate dealing with SIM cards
- Don’t expect cheap, high-volume data. Expect “convenient but kinda pricey backup.”
5. Better alternatives that actually help travelers
This is where Ryoko really loses for most people:
- Local prepaid SIM in your destination country = usually the best price and speed.
- Travel eSIMs (Airalo, Nomad, Holafly, etc.) = super easy, install a profile, buy a local or regional data pack.
- Use your phone as a hotspot instead of carrying a separate brick, if your home carrier has decent roaming offers.
6. Making sense of whether Ryoko is the problem or the network
Sometimes the gadget gets blamed when the local network is just bad. If you want to be a bit nerdy about it, tools like NetSpot are actually useful:
- Install it on a laptop and use it to analyze WiFi quality where you are (hotel, Airbnb, etc.).
- It helps you see if:
- The WiFi coverage from the hotspot is weak
- The underlying internet connection is the bottleneck
- Check out this WiFi analysis and troubleshooting tool if you ever want to deep-dive your connection instead of just guessing.
Short version for your decision:
- No, Ryoko is not a total scam, but it’s heavily oversold.
- It’s sometimes reliable for light travel use, but usually worse value than a local SIM or eSIM.
- With shipping already delayed, I’d:
- Push support for a clear ship date.
- If they stall, cancel and go with a local SIM/eSIM plan.
- If it does arrive, test it before your trip and treat it as a backup, not your main lifeline.
And yeah, the “internet everywhere, super easy, super cheap” promise is basically marketing fantasy.
Cancel Ryoko if it has not shipped. For a simpler setup, prepare your phone for mostly offline travel. Download Google Maps areas, translation packs, boarding passes, hotel details, and entertainment before leaving. Save key addresses as screenshots. Use hotel, airport, and cafe WiFi for messages and updates. Add a trusted VPN for public networks, and avoid banking on them. This costs little, removes delivery stress, and works well for short trips. Keep emergency numbers written down too, becuase batteries and networks fail.
Check the return window before your device even ships, because with delayed shipping you can burn through the return period while the thing sits in transit. That’s the trap nobody flagged yet. Some of these gadget sellers count the clock from purchase, not delivery, so by the time it lands you’re already stuck with it.
The earlier breakdowns on it being a repackaged 4G hotspot are correct, and I won’t rehash that. Where I’d steer a little differently is the eSIM advice. Everyone’s saying eSIM like it’s automatic, but check that your phone actually supports eSIM and isn’t carrier locked. Older phones and a lot of budget Androids still don’t do it. If yours qualifies, an eSIM beats Ryoko on price and hassle almost every time, no shipping involved, you buy it the night before you fly.
One real annoyance with these pocket hotspots that gets glossed over: battery. It’s another thing to charge every night, and if it dies mid-day you’re offline until you find an outlet. Your phone with an eSIM is one less brick to babysit.
On the NetSpot suggestion that came up twice, it’s genuinely handy for the narrow job of figuring out whether the hotel WiFi is weak or your device is, but that’s a home-and-hotel diagnostic, not a travel-connectivity fix. It won’t tell you anything about which carrier to pick abroad. Use it if you’re troubleshooting a specific room’s signal, otherwise it’s beside the point for the buy-or-cancel decision.
My honest take: cancel if it hasn’t shipped, grab an eSIM for your destination, and keep the offline-maps tip @golden_mystic_owl mentioned as your safety net. That combo costs less and doesn’t depend on a courier making it before your flight.
