Is It Possible To Recover Deleted Photos From An SD Card?
I accidentally deleted important photos from my SD card while clearing space, and now I’m trying to figure out if they can be recovered. These pictures mean a lot to me, and I haven’t used the card much since it happened. What’s the best way to recover deleted photos from an SD card without making things worse?
I ran into this once, and yeah, the stomach-drop part hits fast. First thing I did was stop touching the SD card. No more photos, no retrying stuff, no plugging it back into the camera. Take it out and leave it alone.
Deleted photos usually are not erased on the spot. The card marks the space as open, then new data writes over it later. So if you kept shooting after the delete or format, recovery odds drop hard. If the card sat untouched, your odds are still decent, sometimes surprsingly good.
Before installing anything, I’d check the obvious places.
If the delete happened while the card was mounted on a Mac, look in the macOS Trash. If this came from an Android phone, open Google Photos trash or Samsung Gallery recycle bin. Those often keep deleted items for 30 to 60 days. Also check whether your phone or camera app was syncing to any cloud backup.
If none of that turns up the files, then the practical route is recovery software.
One mistake I made the first time was trying to recover through the phone itself. Bad idea. Same with plugging some cameras in over USB and hoping the software will see the card properly. A lot of phones and newer cameras expose a limited view of storage, so recovery tools don’t get raw access to the file system. On phones, many apps want root access, and without it they often pull tiny preview junk instead of full images. What worked better for me was a plain USB SD card reader. Plug the card straight into your Mac or Windows PC and scan it there.
There are a pile of recovery tools out there. Some are free. PhotoRec is one people mention a lot, and it does pull data, but when I used similar tools I ended up with a mess of renamed files and no folder structure. Fine if you have 40 images. Awful if you have 4,000.
I had better luck with Disk Drill. It felt easier to deal with, it recognized common photo formats including RAW types like CR2 and NEF, and the preview feature saved me time because I could tell which files were intact before recovering them.
Here’s the process I’d follow.
1. Install Disk Drill on your computer. On macOS, give it Full Disk Access in Privacy settings or it may not scan external media right.
2. Insert the SD card with a card reader, then open the app. Your card should show up in the drive list.
3. Select the SD card and start a lost-data scan. If you see an option like Universal Scan, use it. It usually checks recent deletions first, then does a deeper pass based on file signatures.
4. Let the scan finish. You can browse during the scan, but I usually wait. Fewer false starts that way.
5. Open the Pictures section when results appear. Filter by format if needed, or scroll through everything. Use the preview icon on each file.
The preview matters more than anything else here. If the image opens cleanly in preview, the file is usually recoverable. If it fails to open, shows broken chunks, weird colors, or half an image, the file is damaged and might not come back clean.
6. Select the photos you want, then hit Recover.
When it asks where to save the recovered files, do not save them back onto the same SD card. Save them to your computer’s internal drive or a different external drive. Writing recovered files onto the source card while recovery is still happening is how people wreck the last salvageable bits. I did this once years ago with a USB stick. Never again.
After recovery finishes, open a handful of the restored photos and check them. Full size. Not thumbnails. Once you know the files are good, then put the SD card back in the camera and format it there for a clean start.
That’s the route I’d take. Slow down, don’t write anything new to the card, and do the recovery from a computer with a proper reader. That part matters more than people think.
Yes, deleted photos from an SD card are often recoverable, if you stopped using the card fast. Deletion usually removes the file entry, not the photo data right away. New writes are the main threat.
I agree with @mikeappsreviewer on one big point, keep the card out of the camera. I disagree a bit on checking device trash first if time matters. If the pics were deleted on the camera, those bins often won’t help, so I’d spend my effort on a proper scan from a computer.
Best move is to make a byte-for-byte image of the SD card first, then scan the image, not the card. This matters if the card has weak sectors or starts failing during reads. On Linux or macOS, people often use ddrescue for this. On Windows, some recovery apps handle imaging too. Then run recovery on the image file.
If you want a simpler route, Disk Drill is solid for SD card photo recovery. It tends to identify JPG, PNG, RAW, and other camera formats well, and previews save time. Save recovered files to your computer, never back to the SD card. That part trips people up alot.
If the card was formatted, recovery still works sometimes. Quick format leaves more behind than full format. If TRIM kicked in, common on SSDs, recovery odds tank. On SD cards, TRIM support is less consistent, so there’s still hope.
Also worth reading this: best recovery software video for deleted SD card photos
Yep, it’s possible, and the fact you barely used the card afterward is the part that actually matters most.
I mostly agree with @mikeappsreviewer and @techchizkid, but I’d add one thing they kinda danced around: if these photos are truly irreplaceable, don’t keep experimenting with random free tools one after another. Every extra mount, scan, or write is another chance for something dumb to happen. Sometimes the safest move is one careful recovery attempt, not five “maybe this one works better” attempts.
Also, people focus on deletion, but card health matters too. If the SD card is acting weird, slow, disconnecting, or asking to be formatted, treat it like possible hardware failure, not just accidental deletion. In that case, imaging first is smarter than direct scanning.
If the card is stable, Disk Drill is a pretty reasonable choice for SD card photo recovery because it handles photo formats well and lets you preview files before restoring them. That preview check is huge. If the image preview looks normal, you’ve probly got a solid recovery candidate. Save everything to your computer, not back onto the card. Obvious, but people still do it somehow.
One small disagreement with @techchizkid: imaging first is ideal, yes, but for a normal healthy card and a non-techy person, going straight to a read-only style scan in Disk Drill is often the more realistic path. Not everybody wants to wrestle with ddrescue at 11 PM while panic-sweating over wedding photos.
If you want a useful thread on this exact issue, this is worth a look:
how to recover deleted photos from an SD card
Short version: stop using the card, use a card reader, recover to another drive, and check recovered files at full size. If nothing useful shows up, then it may be time for a pro recovery service, which is annoyngly expensive but sometimes the only move.
