How To Take Screenshot On Android
I just switched to an Android phone and I can’t figure out how to take a screenshot. On my old device it was a different button combo, and nothing I try seems to work. Could someone explain the different ways to capture a screenshot on Android, including any settings I should check or features like palm swipe or quick settings buttons?
Android loves to change this stuff by brand, so you are not doing anything wrong. Here is the usual list.
  1. Standard button combo on most phones
    • Press Power + Volume Down at the same time
    • Hold for about 1 second, then release
    • Screen should flash and a small preview pops up in the corner
    • If nothing happens, try pressing both buttons exactly together. If you press and hold Power first, it might open the power menu instead
  2. Samsung phones
    • Same combo: Power + Volume Down
    • On older Samsung with a physical Home button
    Power + Home
    • Newer Samsung also has:
    Swipe the side of your hand across the screen from right to left, if Palm swipe to capture is enabled
    To check: Settings > Advanced features > Motions and gestures > Palm swipe to capture
  3. Google Pixel
    • Power + Volume Down
    • Or use Quick Settings:
    Swipe down twice from the top > tap Screenshot
    • On newer Android versions
    Go to Settings > System > Gestures > Press and hold power button
    Turn on Show cards & controls
    Then hold Power, tap Screenshot
  4. Three finger gesture (OnePlus, some Xiaomi, Motorola, etc.)
    • Drag three fingers down on the screen
    • To enable or check:
    OnePlus: Settings > Buttons & gestures > Quick gestures > Three-finger screenshot
    Xiaomi: Settings > Additional settings > Button shortcuts > Take a screenshot
    Motorola: Settings > Display or Gestures, depends on model
  5. From the recent apps screen (Android 11+)
    • Swipe up from bottom and hold to open Recents
    • Under the app preview you see Screenshot
    • Tap it to capture that app only
  6. Assistant method
    • If Google Assistant is on
    Say “Hey Google, take a screenshot”
    • Or swipe from corner to trigger Assistant and tap Screenshot button if it shows up
  7. If none of that works
    • Open Settings > System > Gestures > Screenshot or Quick launch features
    • Search “screenshot” in Settings search bar, it often shows the shortcut location
    • Some manufacturers let you remap buttons or gestures in there, so your combo might be changed by default
Extra tips
• After you take it, you usually see options like Edit, Share, Delete
• Screenshots are stored in Photos or Gallery > Albums > Screenshots
• On work phones with admin controls, screenshots in secure apps might be blocked, so nothing will happen even if you press the combo right
Try Power + Volume Down first, then check Settings and search for “screenshot” if it refuses to work. Different skins love their own rules.
Couple more options that @viaggiatoresolare didn’t hit directly, and a few “gotchas” that might explain why nothing seems to work for you:
  1. Check if your power button was remapped
    Some manufacturers or skins let you change what long‑pressing the power button does, and that can break the usual screenshot combo timing.
  • Open Settings
  • Use the search bar and type “power button” or “side key”
  • If you see stuff like “Side key settings” / “Power button behavior,” look in there for:
    • “Press and hold for…” or
    • “Wake assistant / app shortcut”
      If the phone is trying to launch Assistant or some other action with Power, your Power + Volume Down timing can get finicky. Set it to the default if you can.
  1. Floating / quick ball / shortcut bar
    Some brands (Xiaomi, Vivo, Oppo, some gaming phones) have a floating widget that can take screenshots. Look in:
  • Settings > Special features / Convenience tools / Smart tools
  • Turn on “Quick ball,” “Smart sidebar,” or similar
    Then add “Screenshot” to that bar and just tap it when you need it.
  1. Custom button mapping apps
    If this is a used phone or you restored from an old backup, you might have an app that hijacked the buttons:
  • Check your installed apps for stuff like “button mapper,” “side key helper,” “gesture control,” etc.
  • If you see any, open them and see if screenshot is turned off or mapped to some weird combo.
  1. Accessibility menu shortcut
    This one’s more hidden but super handy if the hardware buttons are flaky:
  • Settings > Accessibility
  • Look for “Accessibility Menu”
  • Turn it on and enable the shortcut (usually a little guy icon or a two‑button shortcut)
    Once it’s enabled, tap that on‑screen shortcut, and you’ll often see “Screenshot” in the menu.
  1. Why it looks like it’s not working
    Couple of easy-to-miss things:
  • Volume up vs volume down: some people keep hitting Power + Volume Up out of habit. On most phones that triggers other stuff (like silent mode) instead of screenshot.
  • Secure content: banking apps, streaming apps, and some “secure workspace” stuff literally block screenshots. So it may work everywhere else but not in that one app. Try taking a screenshot on the home screen first.
  • Animations disabled: if developer options are on and animations are turned to 0x, the “flash” and transition can be so fast you barely see it. Check your Photos/Gallery > Screenshots album anyway.
  1. Last resort: use the search like a cheat code
    Honestly, Android settings are chaos. Do this:
  • Open Settings
  • Use the search bar at the top
  • Type “screenshot”
    You’ll often see every place it’s mentioned: gestures, button shortcuts, accessibility, side panel, etc. That’s the fastest way to find which exact method your model expects.
I slightly disagree with @viaggiatoresolare on one tiny point: it’s not just “different skins love their own rules.” Sometimes carriers and IT admins also mess with defaults, especially on work phones, so if you still can’t get any combo to work, there’s a chance your device policy is blocking it or has changed the shortcut. In that case, check under Settings > Security or “Device admin apps” to see if it’s a managed device.
