I’m trying to print documents directly from my Android phone to my home Wi‑Fi printer but nothing shows up in the print menu. I already installed the printer’s app and made sure both devices are on the same network, but my phone still doesn’t detect the printer. Can someone explain what settings or apps I’m missing and walk me through the correct steps so I can reliably print PDFs and photos from my Android phone?
First thing to check is if Android even sees the printer at system level, not only inside the vendor app.
Try this:
- Open Settings on your phone.
- Go to Connected devices or Connection preferences.
- Look for Printing or Print services.
- Make sure Default Print Service is turned ON.
- Tap it and see if your printer shows up.
If it does, tap it and enable it.
If it does not show:
- Go back to Printing menu.
- Tap Add service or Download plugin.
- This sends you to Play Store. Install the official print service plugin for your printer brand, like:
- HP Print Service Plugin
- Epson Print Enabler
- Brother Print Service Plugin
- Canon Print Service
- After install, go back to Settings → Printing. Turn that plugin ON.
Now test printing:
- Open a PDF or image.
- Tap Share.
- Choose Print.
- In the printer dropdown, select your Wi Fi printer.
If Print is missing from the share menu, try from Google Drive or Chrome:
- In Chrome: three dots → Share → Print.
- In Google Docs or Sheets: three dots → Share & export → Print.
A few network checks:
- Make sure your phone and printer use the same Wi Fi band.
Some routers split 2.4 GHz and 5 GHz into different SSIDs.
Many printers only work on 2.4 GHz. - Disable any VPN on the phone. VPNs often block local devices.
- If your router has “AP isolation” or “Client isolation”, turn it off. That blocks devices from seeing each other.
If the printer only prints from its own vendor app and still does not appear in the Android print menu, try:
- Restart printer, router, phone.
- Assign the printer a fixed IP in the router settings, then power cycle it.
- On some models you need to enable Wi Fi Direct or wireless printing from the printer’s own control panel.
One simple test: from a laptop on the same Wi Fi, try to open the printer’s IP in a browser. If the printer web page loads, the network side looks ok and the Android print service is the missing piece.
If you share the exact printer model and Android version, you will get more precise steps.
Couple things to add on top of what @viaggiatoresolare already said, coming from someone who has wrestled with this nonsense way too many times:
Don’t rely on the vendor’s “all‑in‑one” app
The printer’s own app (HP Smart, Canon PRINT, etc.) can often print only from inside that app, not from the Android system print dialog.
Test this:- Open the vendor app
- Use its “Print document / Print photo / Print from cloud” option
If that works but the printer still never shows in the Android print menu, the app is basically in its own little world and not exposing a proper print service.
Try Google’s “Mopria”-based approach
Some brands integrate with Mopria. Check Play Store for Mopria Print Service and install it. Sometimes this sees printers that the vendor plugin refuses to detect, especially older Wi‑Fi models. Turn it on under Settings → Printing after install. -
Check if the printer actually supports “network printing” and not just “wireless setup”
Super annoying detail: older Wi‑Fi printers support being configured over Wi‑Fi but only print over USB.
Look for things like:- “Wi‑Fi Direct”, “AirPrint”, “Mopria”, “IPP”, “Google Cloud Print” (on very old docs)
If the specs only brag about “wireless setup” or “mobile app” and never once mention AirPrint / Mopria / IPP, then Android system printing might simply never see it.
Test raw network access from your phone
Since @viaggiatoresolare suggested testing from a laptop, do a similar check directly from the phone:- Find the printer’s IP (from its control panel or router)
- On the phone, open a browser and go to
http://printer-ip
If the web page doesn’t load, your problem is network / isolation / wrong subnet, no print plugin will fix that.
If it does load and still no print service finds it, the printer may be using some proprietary discovery method.
Watch out for “guest” or IoT networks
If your router has:- Guest Wi‑Fi
- IoT / “smart home” network
And the printer is on that while the phone is on the main network, they often can’t talk to each other. Even if SSIDs look similar. Move both phone and printer to the same “main” LAN.
Try Wi‑Fi Direct as a workaround
If your printer supports Wi‑Fi Direct:- Turn Wi‑Fi Direct on from the printer panel
- On the phone, connect to the printer’s Direct SSID like a normal Wi‑Fi network
- Then try printing from Android’s Print menu
This bypasses your router entirely. If it works in Wi‑Fi Direct mode but not normal Wi‑Fi, you’re looking at a router / network discovery issue, not an Android problem.
Don’t ignore firmware and Android version
- Update the printer firmware from the vendor app or printer web page
- Check for Android updates on the phone
Some older print plugins straight up do not play nice with newer Android versions until you update firmware or switch to Mopria.
If you can share exact printer model + Android version, someone here can usually tell you in one message whether that combo should show in the print menu or if you’re stuck using only the vendor app.
Two angles that haven’t been hit hard yet:
1. Nuke & rebuild Android’s print stack
Sometimes the Android print subsystem gets stuck, especially after you install/uninstall multiple printer apps.
Try this sequence:
- Go to Settings → Apps → Show system apps → look for:
- “Print Spooler”
- Any vendor print service plugins you tried earlier
- For each:
- Force stop
- Clear cache
- Clear data (for the print services, this just resets detection and settings)
- Disable every print service except one (Mopria or the official vendor print service).
- Reboot the phone.
- Open a generic app (Chrome, Gmail, Drive), hit Share → Print and see if the printer list repopulates.
I’d actually disagree a bit with always piling on more print plugins. Too many at once can make detection worse, not better. Keep it to one active service while testing.
2. Check protocol support the “hard” way
If you can get to the printer’s web page from the phone (as already suggested), dig into:
- Network → Services / Protocols / Advanced
- Look for “IPP”, “IPP Everywhere”, “LPD”, “RAW 9100”, “AirPrint”, “Mopria”
If none of that is there and you only see “Cloud print from our mobile app” or something vague, Android’s built‑in print menu is often a dead end and you’re realistically stuck printing from inside the vendor app only.
If IPP / IPP Everywhere is present but the phone still doesn’t list it after you’ve cleaned the print spooler and kept a single plugin active, then it starts to look like an Android version vs firmware vs plugin compatibility issue, not a pure network problem.
3. Try the “share into app” workaround
While you troubleshoot, a practical workaround:
- Open the document (PDF, image, etc).
- Use Share (not Print).
- Choose the vendor’s printer app directly.
- Print from there.
Clunky, yes, but it bypasses the Android print dialog entirely and usually works even when the system print list is empty.
4. About product choice & alternatives
Since the topic is essentially “How To Print From Android Phone,” the best long‑term “product” to look for is a printer that explicitly supports:
- Mopria
- IPP Everywhere
- Wi‑Fi Direct
Pros if you buy with those in mind:
- Shows up in Android’s print dialog without extra drama
- Works with Mopria Print Service and most vendor plugins
- Easier to move between different Android versions or devices
- Some older cheap Wi‑Fi models do not support these and require the vendor app forever
- Budget printers that only tout “mobile app printing” can lock you into a clumsy workflow
Compared with what @viaggiatoresolare covered, I’d lean less on “try yet another plugin” and more on: either your current device genuinely supports standard network printing or it doesn’t. If it does, cleaning up the print spooler and running a single print service usually makes it appear. If it doesn’t, no amount of app‑hopping will magically make it show in the Android print menu.
If you share exact printer model + Android version, it’s often possible to say flat out: “Yes, this should appear in the print dialog” or “No, vendor‑app‑only forever.”
Use a computer as a simple bridge. Upload the document from your phone to Google Drive, Dropbox, or email it to yourself. Open it on a laptop connected to the printer, then print normally.
This avoids Android’s print menu, plugins, and printer protocol issues. It takes about one minute and works for PDFs, photos, and Office files. If you print often, create a shared “Print” folder in Drive. Drop files there from your phone, then print them from the computer. It’s not direct, but it gets the job done wiht less troubleshooting.
Quick warning on the Wi-Fi Direct trick @sterrenkijker mentioned: while your phone is joined to the printer’s Direct SSID, you usually lose normal internet, so it’s fine for a one-off print but annoying if you’re bouncing between browsing and printing. Good for a diagnostic though, since if it prints in Direct mode your problem is definitely router discovery and not Android itself.
