I’ve been relying on AI tools to help me create blog posts and website copy, but the results often feel stiff, robotic, and obviously machine-written. This is hurting engagement and SEO because readers don’t stay on the page very long. I’m looking for practical tips, tools, or workflows to humanize AI content so it sounds authentic, keeps my brand voice, and still ranks well in search. What strategies are you using that actually work?
I went through the same thing with AI posts. Looked fine at a glance, felt dead when you read it.
Here is what helped me make it sound human and keep people on the page longer.
- Start from a human outline
Do not ask the AI to “write a full blog post”.
You write the outline yourself:
- main angle
- 3 to 5 key sections
- 1 or 2 examples you want in each section
Then feed that to the AI and tell it to expand, not decide.
- Add your own takes and stories
AI outputs neutral takes. Readers bounce on that.
After the AI draft, go through and:
- add “I’ve seen…” or “In my tests…” where true
- add 1 short story or mistake you made
Example: “I tested 3 AI tools for product pages. Time on page went up 18 percent only when I added my own intro and FAQ.”
- Change the structure so it does not feel AI-generated
AI loves the same patterns:
- “In today’s digital age”
- “not only X, but also Y”
- perfect H2, H3 ladders
Break that a bit: - mix short and medium paragraphs
- use bullets only where they help
- put your main point near the top, not in a long build up
- Fix the “AI voice” tells
Search your draft and kill these:
- “in this article”
- “as you can see”
- “moreover, furthermore, hence”
Swap for plain words: - “here is the point”
- “on top of that”
Also, change generic words.
Example: replace “leveraging innovative strategies” with “using a simple checklist”.
- Add real data or specifics
AI guesses a lot. You add the proof.
- mention your own numbers, even if small
- link to 1 or 2 sources, not 10
Example: “After I rewrote intros in a more direct tone, average time on page went from 58 seconds to 1:21 on 9 posts.”
- Rewrite intros and conclusions yourself
These two parts set the tone.
My workflow:
- let AI write the full post
- delete intro and last section
- write my own 3 to 5 line intro that states:
- who this is for
- the main problem
- what they will get
Do the same at the end with 3 clear next steps.
Talk to one person
Switch everything to “you” and “I”, not “users” or “people”.
Example:
AI: “Users might find it difficult to humanize AI content.”
You: “You might feel your AI posts read like a manual.” -
Control sentence rhythm
AI often uses perfect medium sentences.
You want a mix.
Edit each paragraph:
- add a short punch line
- break long sentences in two
This creates a more human reading pattern.
- Keep AI in the background
Use AI for:
- first rough draft
- ideas and variations
- rewriting stiff lines
Do not paste AI output straight into your CMS.
Always do one human editing pass where you: - cut at least 15 to 25 percent of text
- remove repeated ideas
- swap generic phrases for your own words
- Test on one metric at a time
Track:
- time on page
- scroll depth
- newsletter signups from the post
Try:
Post A: raw AI, light edit.
Post B: same topic, but with your own intro, story, data, phrase cleanup.
Check which one holds readers better.
This takes more effort than pure AI output, but it stops the “robotic” feel and keeps your SEO alive because people stop bouncing so fast.
The “make an outline then expand it” thing from @suenodelbosque is solid, but I’ll be honest: if you stop there, your stuff can still feel like a slick brochure.
Here’s what’s worked for me that’s different from their list:
1. Stop asking AI for “helpful” content
Robot-feel almost always comes from this:
You ask for “helpful, comprehensive, informative” and it gives you a nice, safe Wikipedia remix.
Try prompts like:
- “Write this as if you’re slightly annoyed I ignored your advice before.”
- “Explain this like you’re my blunt coworker who’s tired and on their third coffee.”
- “Write first draft in a rough, messy voice, not polished.”
Then keep some of that roughness. Don’t polish it all out.
2. Inject friction and disagreement
AI loves consensus. Humans argue.
Go through the draft and:
- Add 2–3 lines where you push back on common advice in your niche
- “Everyone tells you to post daily. Honestly, that burned me out and did nothing.”
- Add a “hot take” section: “What I don’t agree with” or “Where this advice fails.”
Readers stay when they feel tension or surprise, not when they read another “X is important in today’s digital world” lullaby.
3. Use “live thinking” instead of polished conclusions
AI writes like it knows everything already. Humans sound like they’re figuring it out.
Edit paragraphs so they show your thinking process:
- “At first I thought the problem was my keyword research. It wasn’t.”
- “I tried fixing this with a new template. That made it worse.”
- “Looking back, I should have done X instead of Y.”
It stops sounding like a school essay and starts sounding like a real brain.
4. Keep strategic “imperfections”
If you clean every sentence, the post feels airbrushed and artificial.
Deliberately allow:
- One or two incomplete sentences for punch:
- “That’s it. You’re done.”
- A couple of casual phrases:
- “Yeah, that was dumb.”
- “This part sucked.”
- Natural typos / informal punctuation you’d actually use in a DM
You don’t need to write like an English teacher grading herself.
5. Make your examples oddly specific
I’ll disagree a bit with the “just add a story or two” idea. Generic stories are still AI-ish.
Instead of:
- “I once rewrote a post and engagement went up.”
Use stuff that’s almost too specific:
- “I rewrote a 1,700 word post on ‘best planners for ADHD’ at 1:13 a.m., cut the intro in half, and the next week my average time on page went from 47 seconds to 1:09.”
The weird details are what make it feel like a real person lived it.
6. Limit AI’s “knowledge,” not just its structure
One reason AI reads robotic is it pretends to know everything. Tell it what it’s not allowed to do:
- “Only use info I give you.”
- “If you don’t know, write ‘I’m not sure’ or ‘This part depends on you.’”
- “Do not list more than 3 tips per section.”
That forced humility feels way more human than a list of 19 bullet points nobody asked for.
7. Add a “why this might not work for you” section
AI posts are full of “do X, Y, Z.” Human posts also say “here’s when this fails.”
At the bottom of each main tip, add:
- “This won’t help if…”
- “Skip this if…”
Example:
“Using AI for drafts won’t help if you hate editing. In that case, you’re better off starting from voice notes and having AI clean your words instead.”
8. Record yourself talking, then have AI clean that
Flip the workflow:
- Talk into your phone for 3–5 minutes like you’re explaining it to a friend.
- Paste the messy transcript into the AI and say:
- “Edit this for clarity, but keep my wording and tone as much as possible. Do not add new points.”
That gets you a post that sounds like you, not like the AI. You become the source, not the assistant.
9. Give the reader a mini “assignment”
Robotic content ends with “In conclusion…” and some vague recap. Instead, end with 1 concrete action:
- “Take your last AI post, delete the intro, and rewrite the first 3 lines in the voice you’d use texting a friend. Watch your time-on-page for the next 7 days.”
You want them to do something, not just nod and close the tab.
If you want a quick fix:
Take one of your existing AI posts and do just these three edits:
- Rewrite only the first 4–5 sentences as if you’re slightly annoyed and in a rush.
- Add one hyper-specific example with real numbers or dates.
- Add a “this might not work for you if…” line after your main tip.
Compare that post’s time-on-page and scroll depth with your untouched AI stuff. The difference is usually… not subtle.
