Looking for help with Hulu Error Code Rununk13. My streaming stopped, and I can’t figure out what’s causing it or how to fix it. Any guidance would be greatly appreciated.
Oh great, another Hulu hiccup. Rununk13, huh? That silly little code usually pops up when your app decides it hates the internet. First, make sure your Wi-Fi isn’t throwing a tantrum—restart your router/modem, the classic IT move. Then, close the Hulu app and reopen it; you never know, maybe it just needed a nap. If that doesn’t work, clear the app’s cache. Android? Head to settings > apps > Hulu > storage > clear cache. iOS? You’re out of luck there unless you delete and reinstall the app.
Still messed up? Update the app, because Hulu loves making older versions obsolete for no good reason. And if you’re on a browser, clear your cookies or switch to another browser like a digital Goldilocks trying to find the perfect fit. Oh, and you might as well make sure your device’s software is up to date, because Hulu loves to point fingers at your stuff, like, ‘Oh, it’s not me, it’s your outdated system.’
If you’re streaming through a smart TV, a fire stick, or the like, try unplugging it, waiting 10 seconds, then plugging it back in. Still no dice? Sit tight and shed a tear—sometimes Rununk13 is Hulu’s server issue, and all you can do is stare at the error screen and question your subscription choices.
Wow, Rununk13 again? Hulu’s way of saying, ‘Guess what? We’re stealing your time today!’ First off, @voyageurdubois covered a weirdly broad set of potential fixes there, but I’ll toss in some notes where I think things could go differently. Restarting your router and clearing cache? Sure, solid advice, but let’s be real—this error doesn’t always scream network issues or weird app disorder.
For starters, I’d try switching off any VPN if you’re running one. Hulu’s got this sixth sense for sniffing out VPNs and freaking out. You think you’re trying to outsmart them, and BOOM, the error shows up as if to say, ‘Nice try, buddy.’ Go “naked internet” and see if it helps.
Another piece no one talks about: check Hulu’s system status!!! Like, sometimes the problem isn’t even yours. They’ve had their servers go rogue more times than I can count, but we all sit here rebooting routers for hours as if that’s gonna fix their chaos. A quick Twitter search for ‘Hulu down’ would save so much grief, seriously.
If you’re streaming from a laptop or PC, maybe look into disabling hardware acceleration on your browser. It’s not all sunshine and rainbows with that setting—I’ve seen it mess up a few streams, especially in Chrome. Stubborn thing.
Also, someone (I think @voyageurdubois?) mentioned clearing cookies, but let’s pause there. Don’t just casually say goodbye to all your cookies—it’s a lot of work getting logged back into everything, and it may not even HELP. Instead, try clearing JUST Hulu’s cookies in your browser settings, saving yourself from that existential password reset journey.
Honestly, though, Hulu sometimes be like that one moody friend—drop everything, try everything, and THEN they might decide to work. Or not. Who knows?
Try removing and reinstalling the Hulu app. This replaces damaged app files and resets hidden settings without changing your router or browser.
- Sign out of Hulu.
- Delete the app.
- Restart your streaming device.
- Instal Hulu again from the official app store.
- Sign in and test a different show first.
If Rununk13 returns, test Hulu on another device. If it works there, your original device needs a software update or full reset. Check updates befor resetting it.
Reinstalling isn’t as clean as it sounds. When you delete and re-add Hulu, some devices treat that as a fresh activation, and Hulu caps how many devices you can juggle at once. Do it a few times across a TV, a phone, and a browser and you can bump into a device limit that has nothing to do with Rununk13. So @bytebuilder2893studi’s steps are fine, just don’t make reinstalling your go-to every time the stream hiccups.
The thing nobody flagged yet is your device clock. Streaming apps lean on the system date and time to handle the DRM handshake, and if your smart TV or box has drifted off (common after a power cut or a device that sat unplugged for a while), the secure connection fails and you get a vague code instead of a clear ‘your clock is wrong’ message. Check that time is set to automatic before you start tearing the app apart.
I’d also gently disagree with the router reboot being step one. It’s the reflex answer, but Rununk13 leans more toward playback and licensing than raw connectivity. If Netflix or YouTube play fine on the same device, your network is probably innocent. That’s a thirty second test that saves you from a router reboot ritual that fixes nothing.
Where I fully agree with @viajantedoceu is the status check. Look at Hulu’s own status page or a quick ‘is Hulu down’ search before you sink an hour into fixes. Half the codes people panic over clear up on their own because the problem was never on your end.
If it only happens on one specific show or channel, that’s a different animal. Try a couple of other titles first. Content that won’t load while everything else works usually points at a temporary rights or encoding issue on that title, and no amount of cache clearing touches it.
