How do I AirPlay from my iPhone to my Roku?
Trying to watch videos from my iPhone on a Roku device. Followed some steps like enabling AirPlay on Roku, but it’s not working. Anyone know what might be wrong or missing? Need help to get this set up. Thanks in advance!
Alright, so you’re trying to AirPlay from your iPhone to your Roku, but it’s being a pain. First off, make sure your Roku and iPhone are on the same Wi-Fi network. That might sound basic, but you’d be surprised how often that’s the issue.
Next, on your Roku, go to Settings > Apple AirPlay and HomeKit, and make sure AirPlay is turned on. If it’s not, well, that’s kinda necessary.
Now, on your iPhone, open the Control Center (swipe down from the top-right corner on newer iPhones or swipe up from the bottom on older models) and tap the Screen Mirroring button. Your Roku should show up in the list. Tap it, and voila, your phone screen should appear on your Roku.
If that’s not happening, there could be a few more things to check:
  1. Software Updates: Make sure both your Roku and iPhone have the latest software updates.
  2. Compatibility: Some older Roku models might not support AirPlay.
  3. Firewall: Sometimes a firewall setting on your network can block AirPlay.
If all else fails, consider trying the DoCast app.
How to Stream Videos from iPhone to Roku with DoCast
  • Install DoCast
  • Ensure your iPhone and Roku TV/device are on the same Wi-Fi network.
  • Open DoCast and Select Roku.
  • Tap the Videos option in DoCast.
  • Browse and select the video files stored on your iPhone that you want to stream.
  • Once selected, the video will start playing on your Roku-connected TV.
Here’s a quick tip: I often find myself losing the Roku remote or having the batteries die in the middle of a show. When that happens, I use TVRem on my iPhone to turn it into a full Roku remote. It’s not for mirroring, but it’s super helpful for navigating menus, opening apps, or adjusting settings without searching for the physical remote.
:white_check_mark: Conclusion
DoCast makes streaming videos from your iPhone to a Roku TV simple and convenient, especially if AirPlay isn’t available or isn’t working. By connecting both devices to the same Wi-Fi network, you can easily select and play your favorite videos directly on the big screen without cables.
Best of luck! :wink:
Seems like you’re kinda stuck trying to AirPlay from your iPhone to your Roku. @sternenwanderer covered some good ground, but here’s another angle to check out. Sometimes, even with everything seemingly perfect, you might still run into snags.
  1. Reset Network Settings: If ensuring both devices are on the same Wi-Fi network didn’t work, try resetting network settings on your iPhone. Go to Settings > General > Reset > Reset Network Settings. Just remember, this will wipe out your saved Wi-Fi passwords, so note them down!
  2. Quality of Wi-Fi Signal: Sometimes the distance from your Wi-Fi router can affect connectivity. Ensure that both devices are within a good range of your Wi-Fi signal.
  3. Settings Misconfigurations: Sometimes, despite enabling AirPlay on Roku, specific settings might have been misconfigured. Try disabling and re-enabling AirPlay on your Roku.
  4. Different Network Bands: Check if your Roku and iPhone are on the same Wi-Fi band. Sometimes dual-band routers can cause issues by separating devices on 2.4 GHz and 5 GHz bands.
  5. Restart Everything: You’d be surprised how often this works. Restart your router, your Roku, and your iPhone. This step helps clear out minor bugs and refreshes the network connections.
For those still having trouble, the DoCast app can be a lifesaver. It simplifies screen mirroring and bypasses a lot of the fuss.
And don’t forget to try the steps on how to AirPlay your iPhone content to Roku, which could clarify if any specific setting is being overlooked.
Hope you get this sorted out soon! :crossed_fingers::sparkles:
Alright, looks like @reveurdenuit and @sternenwanderer have given you some solid advice. Here’s another angle to consider.
Additional Steps to Try:
  1. Bluetooth Interference: Sometimes, Bluetooth devices nearby can interfere with the signal. Disable Bluetooth on your iPhone and see if that helps.
  2. Restart AirPlay on Roku: Instead of just toggling it off and on, try doing a complete restart of the AirPlay service on your Roku. Navigate to the relevant menu and turn it off, restart your Roku, then enable it again.
  3. Factory Reset Roku: As a last resort, you may consider doing a factory reset on your Roku. Keep in mind this will wipe all settings and installed channels, but it can sometimes solve stubborn connectivity issues.
The DoCast App:
  • Super easy to use.
  • Often resolves quirky connection issues on the first go.
  • Simplifies the screen mirroring process.
  • It’s an additional app, meaning extra steps to set up.
  • May involve a one-time purchase or subscription fee.
Other Solutions:
  • Check for Interference: Make sure there’s nothing like a microwave or large metal object between your devices and your router.
  • Manual IP Entry on iPhone: It’s a bit of a stretch, but manually entering your Roku’s IP address in the AirPlay settings can sometimes force a connection.
Given these tips, one should be able to get around the issues you’re currently experiencing with AirPlay on your Roku. Don’t forget the DoCast app; it definitely has its pros and cons but can be a reliable backup.
Skip AirPlay and use the Roku “Play on Roku” feature in the Roku mobile app.
  1. Install the official Roku app on your iPhone.
  2. Connect iPhone and Roku to the same Wi Fi.
  3. Open Roku app, pick your Roku device.
  4. Tap Photos+ in the app.
  5. Choose videos or photos from your iPhone and send them to the TV.
This avoids AirPlay issues and works reliably for local media.
