How can I format a corrupted SD card on my Mac?
My SD card got corrupted, and now my Mac won’t recognize it. I need to format it to try to recover it. Any recommendations or step-by-step guides on how to do this on a Mac?
If you’re dealing with a corrupted SD card on your Mac, there are a few steps you can follow to try to format it and recover it. Here’s a step-by-step guide:
Step 1: Check Connection
Before anything, ensure the SD card is properly inserted. Try using a different card reader if available.
Step 2: Open Disk Utility
  1. Open Finder.
  2. Navigate to Applications > Utilities > Disk Utility.
Step 3: Locate Your SD Card
  • If your SD card shows up in Disk Utility, click on it.
  • If it doesn’t appear, it’s possible the card is severely corrupted. You might want to try using a professional recovery tool.
Step 4: Erase the SD Card
  1. With the SD card selected, click ‘Erase’ at the top.
  2. Choose a format (e.g., ExFAT or MS-DOS (FAT) if you plan on using it with non-Mac devices as well).
  3. Click ‘Erase’ again.
Step 5: If Erasing Fails
Sometimes Disk Utility might fail to erase corrupted drives. In such a case, professional software like Disk Drill for Mac might come handy. Here’s how you can use it:
  1. Download and install Disk Drill for Mac from their official site.
  2. Launch Disk Drill and select your SD card from the list of available drives.
  3. Use the built-in recovery tools to try and repair the corrupted file system.
  4. If successful, attempt to format the card again through Disk Drill or Disk Utility.
Extra Tips:
  • Make sure your Mac is up-to-date.
  • Backup important data regularly to avoid future issues.
By following these steps, you should be able to format your corrupted SD card. If all else fails, Disk Drill for Mac often proves effective in recovering and repairing data from such scenarios.
For additional advice, you can check out some expert insights on this forum. It covers numerous techniques and tips for dealing with SD card issues, which might provide you with more solutions.
@espritlibre offered some solid steps, so I’ll just add a few more insights to give you another angle.
If your SD card doesn’t show up in Disk Utility, you might try booting into Recovery Mode. To do this:
  1. Restart your Mac and hold down Cmd + R until you see the Apple logo.
  2. Once in Recovery Mode, open Disk Utility from the Utilities menu.
Sometimes, formatting from Recovery Mode can bypass some of the issues encountered in the regular OS environment.
Another potential method is using Terminal for low-level disk operations. Here’s how you can do it:
  1. Open Terminal (found in Applications > Utilities).
  2. Type diskutil list and hit Enter. This command will list all connected drives.
  3. Identify your SD card by its size and label (like /dev/disk2).
  4. Run diskutil eraseDisk FAT32 nameofdrive /dev/diskX, replacing nameofdrive with a suitable label and diskX with your SD card’s identifier.
This command forces a format which might succeed where Disk Utility fails.
For a deeper dive into SD card recovery methods, have a look at this useful resource on how to recover corrupted SD card on Mac.
Lastly, check if a different OS can recognize and format the card. Sometimes Windows or Linux can format drives that macOS can’t.
So, there’s plenty of routes to try. Best of luck, and keep us posted on what worked for you!
I’ve seen similar situations where SD cards went haywire. While @himmelsjager and @espritlibre provided great advice, there’s another angle that might be worth trying before jumping straight into heavy-duty software solutions.
One option that you might consider is using a Linux live USB to attempt the format. Linux often proves to be more forgiving and capable when dealing with corrupted drives. Here’s a quick rundown:
Creating a Linux Live USB:
  1. Download a Linux distro like Ubuntu from their official site.
  2. Use a tool like Etcher to create a bootable USB drive with the Linux distro.
  3. Boot your Mac from this USB by holding down the Option key during startup and then selecting the USB drive.
Using Linux to Format your SD Card:
  1. Once booted into Linux, open the Disks utility.
  2. Select your SD card from the list of drives on your left.
  3. Click on the gear icon and choose Format Partition. Here, you can choose the file system format that suits your needs (probably FAT32 or ExFAT).
Pros: Linux provides a different environment that might be able to bypass the corruption issues seen on MacOS. It’s a bit technical, but quite effective.
Cons: It’s an indirect process and could be a bit overwhelming if you’re not familiar with Linux.
As for professional software solutions, Disk Drill for Mac is, indeed, a solid option. It’s user-friendly and has strong recovery features.
  1. Effective recovery and repair options.
  2. Easy-to-use interface.
  1. Not free – it can get a bit pricey.
  2. Might not work on severely damaged SD cards.
Competitive alternatives like Recoverit or Data Rescue are also pretty good. Each has its pros and cons, with slight differences in features and pricing. However, the steps by @espritlibre using Terminal commands can sometimes work better for more straightforward issues that don’t require complex recovery.
Also, don’t forget, sometimes just using a different card reader can solve the problem without diving deep into software hacks or alternative OS methods.
Lastly, sometimes taking the SD card to a physical tech repair shop can offer solutions if all else fails.
Best of luck, and let us know which method does the trick!
