I’ve been trying to quit porn for a while, but I keep slipping back into it, especially when I’m stressed or bored. It’s hurting my relationships, my focus, and how I feel about myself. What practical steps, tools, or routines actually work long term to stop watching porn and break this habit for good?
I went through this for years. What helped was treating it like a behavior problem, not a moral failure.
Here is what worked for me, step by step.
- Remove frictionless access
- Install blockers:
- On PC: Cold Turkey Blocker, K9 (older but still works on some setups), or BlockSite.
- On phone: BlockSite, Stay Focused, SPIN Safe Browser.
- Give the password to a trusted friend or partner. Do not keep it yourself.
- Turn off private mode on browsers if you can. Use one safe browser only.
- Log out of social media that keeps pulling you into sexual content.
- Identify your triggers in detail
Write down for one week:
- Time you slip.
- Where you are.
- What you felt 30 minutes before.
- What you were doing.
Patterns show up fast.
For me it was: late at night, alone, stressed from work, phone in bed.
- Create a “when urge hits, I do X” list
Decide in advance. Not in the moment. Examples:
- 20 pushups and 20 squats.
- Cold shower for 2 minutes.
- Walk outside for 10 minutes.
- Text a friend the word “check-in” so they know you want to stay clean.
You replace the habit instead of pure willpower.
- Change the environment, not only your mindset
- Keep phone in another room at night. Use a cheap alarm clock.
- No screens in bed, couch, or bathroom. Only at desk or table.
- If you live alone, move your desk so the screen faces the door.
- Use Wi-Fi off after a fixed hour. Put router on a smart plug with a schedule or put it out of reach.
- Set clear rules, no fuzzy stuff
Example rules:
- No porn at all.
- No erotic stories.
- No explicit Instagram or TikTok pages.
- No edging.
Fuzzy rules lead to loopholes. “Only a little” usually fails.
- Track streaks and data
- Use a habit app: Streaks, HabitBull, Habitica, or even a simple calendar.
- Mark each clean day.
- When you slip, write:
- What happened.
- What trigger.
- What you will change next time.
Treat it like a small experiment, not a collapse.
Some data from studies:
- Many people who quit porn report lower anxiety and more sexual satisfaction with partners after 3 to 6 months.
- Urges often spike in the first 2 to 3 weeks, then level off.
Knowing this helps when it feels endless.
- Replace the dopamine source
You are used to quick, high stimulation. You need healthier sources or your brain will chase porn again.
Pick 2 or 3 of these and do them daily:
- Strength training.
- Cardio for 20 minutes.
- Creative work, like music or drawing.
- Skill learning, like language or coding.
The goal is not perfection, only consistent action.
- Deal with stress in better ways
Since your main slip time is stress or boredom:
- Use a 5 minute timer and breathe slowly, 4 seconds in, 6 seconds out.
- Keep a notepad and quick-brain-dump your worries.
- Use short walks as default response to stress.
Porn becomes a fake coping tool. You replace the coping, the urge weakens.
- Tell at least one person
This sucks but helps a lot.
- A friend you trust.
- A partner.
- Or an anonymous group like NoFap forums or /r/pornfree.
Report your streak once a week. Shame grows alone. Accountability cuts it.
- Make a relapse plan in advance
You will slip sometimes. Plan what happens then. For example:
- Delete any new accounts or bookmarks within 10 minutes.
- Write what led up to it.
- Add one new safeguard.
- Get back on streak the same day, not “from Monday”.
Relapse is data, not identity.
- Work on your relationship to sex and intimacy
Porn often twists expectations.
- Focus more on connection with your partner, not performance.
- Reduce fantasy time. When you notice daydreaming, pull attention back to your body or surroundings.
- If you have erectile or arousal issues with real partners, talk to a therapist or doctor. Many people improve after some porn free time.
- Consider therapy if possible
Look for someone who works with:
- Behavioral addictions.
- Anxiety or depression.
- Sexual compulsivity.
Sometimes porn is a symptom of deeper pain like loneliness, shame, or old trauma.
A simple starting plan for the next 7 days:
Day 1: Install blockers, give password away, set phone sleeping place outside bedroom.
Day 2: Write your triggers from the last month, even from memory.
Day 3: Create your “urge response” list and stick it on the wall.
Day 4: Remove social media or accounts that pull you in.
Day 5: Start a 10 minute daily walk and write your daily streak.
Day 6: Tell one person or post your commitment on a forum.
Day 7: Review the week and adjust rules.
You are not broken. You trained your brain into a loop. With structure, you train it out. It takes time, but it works.
Honestly, I think @suenodelbosque nailed the “external controls” and habit side of it. I’ll go a bit in a different direction and focus more on what’s happening inside and why willpower + blockers alone keep failing for a lot of people.
1. Stop making “quitting porn” your whole identity
Weirdly, obsessing over “I must not watch porn” keeps your brain orbiting porn all day. The more you stare at the “don’t press this red button,” the more your brain wants to press it.
Shift the target from “I must quit” to “I am building a life that makes porn feel small and boring.”
Concrete stuff:
- Set 2 or 3 non‑porn goals that genuinely excite you: strength goal, side project, creative thing, social goal.
- Every time you feel “I want porn,” ask: what tiny action gets me closer to one of these goals? Do that, even for 5 minutes.
2. Figure out what porn is doing for you emotionally
Most people think the problem is “horniness.” Often it’s:
- numbness
- loneliness
- shame
- feeling like a failure
Porn then becomes: anesthesia, comfort, distraction, fake intimacy.
Next time you slip or almost slip, ask yourself: - “What emotion am I trying not to feel right now?”
If you can name it (lonely, angry, bored, empty), you can handle it: - Lonely → message someone, go to a public place, join a voice chat, whatever minimal human contact you can stand.
- Overwhelmed → write a 5‑item to‑do list and finish one tiny thing.
- Empty / numb → movement: walk, stretch, music and pacing around the room. You’re trying to wake your body back up.
3. Work directly with the urge instead of instantly fighting it
This might sound backwards, but constantly white‑knuckling can backfire. Try “urge surfing”:
- When the urge shows up, do nothing for 5 minutes. Not yes, not no. Just observe it.
- Pay attention: where do you feel it in your body? Chest? Stomach? Throat? Heat? Tightness?
- Breathe slowly and watch it like a wave: it rises, peaks, then drops.
Urges are usually 10–20 minutes of intensity, not hours. Training yourself to see “oh, this thing passes even if I do nothing” breaks a lot of the panic.
4. Drop the all‑or‑nothing perfection trap
Here’s where I slightly disagree with super rigid “no erotic anything whatsoever or you’ve completely failed.”
For some people, that works.
For others, the pattern becomes:
“I was clean for 14 days → had one slip → brain says ‘you’re trash anyway, might as well binge for 3 days.’”
Instead of counting “perfect days,” track:
- How many minutes of porn did I watch this week vs last week?
- How long was the gap between last two sessions?
You’re trying to trend downward, not magically be pure overnight. Progress > purity fantasy.
5. Make your shame smaller and your honesty bigger
Porn sticks so hard because it’s hidden. You hate yourself for it, then you use it to run from that same self hatred. Terrific little loop.
What breaks the loop is not heroic discipline. It’s honesty:
- Write a private, brutally honest page about what porn has cost you: time, energy, confidence, sex life, self respect. Read it when the “meh it’s not a big deal” voice starts.
- Then write what you actually want your sexuality to be: with a partner, with yourself, your values, your vibe. Revisit that too.
You’re not just quitting something bad; you’re moving toward a different kind of sexual life.
6. Fix the “dead zones” in your day
Most relapses happen in super predictable “dead zones”:
- Late night phone scrolling
- After work, before dinner
- When you get home to an empty space
Instead of just blocking porn in those times, program them: - Create a fixed “evening script”: shower, small snack, 10 pages of a book, light stretching, then bed. No options.
- Turn one dead zone into a “connection slot”: call someone, group chat, gym, class, anything. If you live alone and your evenings are silent, porn will always look attractive. You need something better than silence + wifi.
7. Check for underlying stuff that makes this 10x harder
Not saying this as a cop‑out, but it’s real:
- Depression, ADHD, anxiety, trauma, social isolation… all make compulsive porn use way more likely.
If you: - constantly feel numb
- can’t focus on anything unless it slams your brain with dopamine
- feel like nothing in life feels rewarding
…then you probably need to address that too, not just “stop porn.” Therapy, meds if appropriate, ADHD tools, social skills work, etc. Quitting gets way easier when your baseline life doesn’t suck.
8. Redefine “slip” as feedback instead of proof you’re broken
After a slip, instead of:
- “I’m disgusting, I’ll never change,”
ask 3 mechanical questions:
- Where was I?
- What was I feeling right before?
- What tiny change would have made that moment harder to relapse in?
Then implement one change. Not ten. One. Maybe:
- Move your phone charger to another room.
- Go to bed 30 minutes earlier.
- Don’t come home straight after work, go somewhere public first.
Each relapse becomes a lesson rather than a full reset.
9. Build real sexual experiences, not just restriction
This part gets ignored a lot. Porn is a cheap, controllable, high‑stim version of sex. If your real sexual life is:
- nonexistent
- full of anxiety
- or always tied to shame
…then your brain will keep reaching for the fake version.
You can: - Learn actual sex education, consent, communication.
- Focus on slow, connected experiences with a partner, not performance fireworks.
- Practice feeling attraction in normal life and not instantly turning it into a porn fantasy.
10. Accept that this might be a long project, not a 30‑day “challenge”
You trained your brain over years. It’s not insane that unwinding it may take months or longer.
Instead of “I must never slip again,” try:
- “For the next year, I’m working on upgrading my whole relationship with stress, boredom, and sex. Porn reduction is one measurement of that.”
It sounds slower, but paradoxically it works faster because you stop quitting every time you’re not perfect.
If you put @suenodelbosque’s external systems + your own inner work on emotions, shame, and real life goals together, you’ve basically got both sides covered. The combo is what usually shifts this from endless relapsing to actually getting your control back.
Quick analytical breakdown, focusing on angles that weren’t covered as much by @himmelsjager and @suenodelbosque.
They both nailed blockers, triggers, environment and the emotional side. I’ll zoom in on three different layers: identity, embodiment and system design. I’ll also push back a bit on the idea that you must always go “total abstinence right now or nothing.”
1. Decide who you are around porn, not just what you do
Both other replies focus on actions. Useful, but you also need an identity frame, or your brain keeps negotiating every time.
Try something like:
- “I am someone who treats sexual energy as something valuable, not disposable.”
- “I am someone who does not consume sexual content made through exploitation.”
You are not saying “I am pure” or “I am an addict.” You are describing values. Then every decision is:
“Does this action fit that identity?”
This is stronger than just “I’m on a streak” because streaks break; values don’t have to.
Small practice: once a day, write one sentence:
“Today I acted like someone who values X when I did Y.”
You are training your brain to notice congruent behavior, not just failures.
2. Work with your body, not only your browser
One thing that gets overlooked: porn is highly disembodied. You’re in your head, staring at pixels, barely aware of your own body except for genitals.
If you keep your body out of the conversation, you’ll keep defaulting to that pattern.
Concrete things that help reconnect:
Slow solo touch without porn
This is controversial and some will disagree, but for some people, banning all masturbation just fuses “arousal = danger.”
A middle way: occasionally masturbate without porn, slowly, with focus on sensation in your body, not fantasy escalation. The goal is to learn “arousal is safe and can be grounded” instead of “arousal means I must sprint to porn ASAP or clamp down.” -
Embodiment drills when urges spike
Not just pushups. Try:- 30 seconds: feel both feet on the floor, press them down.
- 30 seconds: notice contact points of your body with chair or bed.
- 60 seconds: breathe into belly, exhale longer than inhale.
You are bringing the nervous system out of “tunnel vision + compulsion” into “present + regulated.”
I partly disagree with only using extreme measures like cold showers. Those can work, but if every urge is treated like an emergency, you never learn calm arousal. You want “this is just energy; I can move it, not panic about it.”
3. System design: think in “pipelines,” not isolated habits
Instead of just “don’t watch porn at night,” map the chain that leads there.
Example pipeline:
- Work stress
- Doomscrolling “to relax”
- Half‑sexy content appears
- Click, escalation, porn
Change the system by touching earlier segments:
- After work, never go straight to bed or couch with phone. Route yourself through a different action: walk, light snack at table with a physical book, short call.
- Put “phone parking spot” in a non‑bedroom location at a specific hour.
- Replace “I relax by scrolling” with “I relax by something mildly stimulating but not hyper: podcasts, audiobooks, longform articles printed out.”
You’re not relying on willpower at step 4. You’re redesigning steps 1 to 3 so step 4 doesn’t fire as often.
4. Time‑boxing instead of fantasy “forever”
Where I do disagree slightly with both of them: for some people, saying “I will never watch porn again” creates so much pressure that it backfires.
Alternative: time‑boxed experiments.
- “For 14 days I am running an experiment where I live as if porn does not exist.”
- At the end, you review data: moods, focus, social behavior, sexual function.
Then extend: 14 → 30 → 60. This keeps the brain from going into “eternal deprivation” mode while still letting you stack real changes.
Treat it like lab work: hypothesis, experiment, data.
5. Bring in meaning, not only “health benefits”
One subtle trap: only talking about quitting porn in terms of “better focus, more energy, less anxiety.” Those are good. They are not always enough to override mid‑night cravings.
You need a meaning story:
- Maybe you want your attention back because you want to be the kind of partner, parent or friend who is truly present.
- Maybe you don’t want your sexuality controlled by an industry that often rides on exploitation.
- Maybe you’re simply done outsourcing intimacy to your screen.
Write your own “why” paragraph. Read it when you are not triggered, so it imprints as your baseline narrative.
6. On tools and products
You mentioned tools, so I’ll be blunt about what I actually think matters in a product that helps with this:
A good tool should:
- Make patterns visible (time of day, duration, triggers).
- Nudge you before your usual relapse window, not after.
- Force small reflection after slips without burying you in guilt.
If you ever consider a structured tracker or blocker bundle like something titled just by a clear keyword phrase such as “porn blocker & habit tracker app,” pros and cons typically look like:
- Central place to log urges, slips and triggers.
- Can bundle blocking, journaling, and streak tracking so you don’t juggle five apps.
- Some add “check in” prompts that remind you of your values and plan when you’re vulnerable.
- You can become obsessed with streak numbers and forget deeper change.
- If everything is in one app and you delete it after a relapse, you lose all data.
- Over‑reliance on a tool can mask underlying loneliness, depression or relationship issues.
Always remember: tools are crutches, not legs. Use them to walk while you rebuild your own muscles.
Competitor‑wise, you basically already have two “approach templates” in this thread:
- @himmelsjager: more on internal emotional dynamics and identity.
- @suenodelbosque: more on environmental control and external systems.
A product or system that combines both sides is usually more effective than one that only punishes access or only talks about your feelings.
7. When you relapse: zoom out, do not dig in
Last piece, very specific:
When you slip:
- Stop after orgasm. Do not extend it into a binge if you can help it.
- Within 15 minutes, write three bullets:
- What was I trying not to feel / think?
- What part of the pipeline did I ignore?
- One change I can make before this same time tomorrow.
- Then do something small but aligned with your values within the hour: tidy one area, send one honest message, do 10 minutes of exercise.
You are teaching your brain that even after a fall, the next behavior can still be aligned with who you want to be. That destroys the usual “I failed, so screw it” spiral.
You already have solid tactical playbooks from the other two answers. The missing piece for many people is this combination:
- Clear values & identity
- Body‑level regulation
- System design instead of heroics
Put those together and slipping doesn’t magically vanish, but it stops feeling like this mysterious force that owns you. It becomes a pattern you understand and can keep reshaping.
