Can someone explain how to screenshot on a Chromebook?
I just switched from a Windows laptop to a Chromebook and I can’t figure out how to take a screenshot the way I used to. I need to capture full screens and specific sections for work tutorials and school projects, but the keyboard shortcuts I know don’t seem to work here. Can someone walk me through the easiest ways to screenshot on a Chromebook, including any built-in tools or settings I should know about?
Here is the Chromebook screenshot stuff in plain English.
Full screen:
  1. Press Ctrl + Show windows
    • Show windows key is the one on the top row, looks like a rectangle with two lines.
  2. Your screen flashes.
  3. Screenshot goes to:
    • Clipboard
    • “Screenshots” folder inside Files > My files > Downloads
Partial screen:
  1. Press Ctrl + Shift + Show windows.
  2. Screen dims, cursor turns into crosshair.
  3. Click and drag the area you want.
  4. Release mouse.
Specific window:
  2. At the bottom, pick the window icon.
  3. Click the window you want.
Screen capture toolbar:
  2. At the bottom of the screen you see options:
    • Take photo style screenshot
    • Record video
    • Switch between full, window, partial
  3. This is good for tutorials.
Where to find files:
  1. Open Files app.
  2. Go to My files > Downloads > Screenshots.
  3. You can drag from there into Google Docs, Slides, or Gmail.
  4. Or right click and pick “Copy” then “Paste” where you need it.
Quick paste:
Right after a screenshot, press Ctrl + V in a doc, slide, or email. Chromebook keeps the last screenshot in clipboard.
For school or work:
• For step by step tutorials, use partial screenshots so you do not show your whole desktop.
• For video walkthroughs, use the same toolbar and pick “Screen record”.
• If you use an external keyboard without a Show windows key, press Ctrl + F5 instead.
Common problems:
• If nothing happens, check if your keyboard has a “Screen capture” key on the top row.
• If storage is full, Files app shows an error and screenshots fail. Clean Downloads folder.
After a week or so, Ctrl + Show windows becomes muscle memory.
@mikeappsreviewer covered the shortcuts nicely, so I’ll just fill in the gaps and some “real life” tips from using this daily for class + work.
  1. Use the Screen Capture button instead of memorizing keys
    If you hate shortcuts, look in the bottom right system tray (where the clock/Wi‑Fi are).
    • Click that area
    • Look for “Screen capture” in the quick settings panel
    • That opens the same toolbar as Ctrl + Shift + Show windows, with options for screenshot vs screen record, full / window / partial.
      This is slower, but easier when you’re still learning.
  2. Change where screenshots are saved
    By default they go in Downloads > Screenshots. That gets messy fast.
    • Press Ctrl + Shift + Show windows to open the toolbar
    • On the right side, click the gear icon (settings)
    • Change “Save to” to Google Drive or a custom folder like “School Screenshots”
      Super handy if you jump between devices or need them backed up.
  3. Make it feel more like Windows “Print Screen”
    Not exactly the same, but you can:
    • Take full screen with Ctrl + Show windows
    • Then open your doc or slide and just hit Ctrl + V
      That flow is the closest to the old Print Screen + paste move. You almost never have to open the Files app if you work this way.
  4. For tutorials: turn on the pointers & mic in screen recording
    When you open the screen capture toolbar and switch to video:
    • Click the gear icon again
    • Turn on microphone recording
    • Turn on “Show taps” or “Highlight mouse cursor” if available
      That makes Chromebook tutorials actually watchable instead of “where is their cursor??”
  5. Quick cropping after the fact
    If your selection is a bit off, you don’t have to retake:
    • Open Files
    • Double‑click the screenshot
    • Click the little pencil icon to edit
    • Crop, rotate, adjust
      Chromebook’s editor is basic, but fine for trimming stuff you don’t want students / classmates to see.
  6. For school projects specifically
    • In Google Docs: Insert > Image > From computer if you saved it, or just Ctrl + V if you grabbed it recently.
    • In Slides: same thing, or drag directly from the Files app into a slide.
      Screenshots of partial areas look a lot cleaner in slides than dumping your entire screen with a million tabs open.
Tiny disagreement with @mikeappsreviewer: I’d actually recommend starting with the toolbar instead of memorizing all three shortcut combos. Once you understand the options there, the shortcuts make a lot more sense and you remember them naturally instead of turning your fingers into a knot.
After a couple days, you’ll probably only use:
  • Ctrl + Show windows for full
  • Ctrl + Shift + Show windows for everything else via the toolbar
Took me like a week to stop missing the Windows Print Screen key, then I realized this setup is kinda better.
You already got the “how” from @yozora and @mikeappsreviewer, so I’ll zoom in on using Chromebook screenshots effectively for work/tutorials.
1. Keyboard vs toolbar: pick one workflow and stick to it
I slightly disagree with the idea that you should start with the toolbar. If you are coming from Windows “Print Screen,” it is actually faster to train on:
  • Full screen: Ctrl + Show windows, then immediately Ctrl + V into Docs/Slides/email
  • Partial or window: Ctrl + Shift + Show windows, pick your mode once, and keep reusing it
The toolbar is great for discovering features, but for day‑to‑day work it adds an extra click. Power users usually end up barely opening it.
2. Treat screenshots like project files, not downloads
Both others mentioned the Downloads > Screenshots folder, which is fine at first, but for serious tutorials and school projects:
  • Create a folder like Projects > Tutorial XYZ > Screenshots in the Files app
  • In the screen capture settings, change “Save to” to that folder
  • When the project is done, move that whole project folder to Google Drive or an external drive
This keeps screenshots tied to a project instead of scattered in a giant Downloads graveyard.
3. Clipboard history is your hidden superpower
For tutorials where you grab several screenshots quickly:
  • Turn on Clipboard history:
    • Settings > Device > Keyboard > enable “Show clipboard history”
  • After taking multiple screenshots, press Search + V (or Launcher + V)
  • Pick from your last few screenshots without digging in Files
This is the closest thing to doing rapid‑fire “Print Screen” captures and then inserting them in order.
4. Make Chromebook screenshots clearer for tutorials
Chromebook screenshots are crisp, but you can make them more tutorial‑friendly:
  • Work in windowed mode with fewer distractions instead of full screen
  • Increase display scale temporarily so UI elements look bigger in the screenshot
    • Settings > Device > Displays > Display size
  • Open the screenshot in the built‑in editor and use crop + annotation (if available) to highlight the exact button or menu
This helps your viewers focus on the action instead of your taskbar, wallpaper, and a row of unrelated tabs.
5. For recorded tutorials: plan around the screen capture toolbar
Where @yozora emphasized mic and pointer, I’d add:
  • Record just a specific window, not the whole desktop, so private stuff stays hidden
  • Do a 10–20 second “test run” first to make sure the mic volume and resolution are acceptable
  • Keep a short script next to your recording so you are not hunting for what to show next
It feels slower at first, but your final tutorial looks way more professional.
6. Quick compare with what @yozora and @mikeappsreviewer covered
  • They nailed the shortcut combinations and the basic file locations
  • I would lean harder on clipboard history and custom save locations for real work
  • Toolbar is fantastic for learning, but once you know the options, shortcuts are what actually speed you up
Once you set a default “save to” folder and get used to Ctrl + Show windows followed by paste, the Chromebook screenshot flow ends up smoother than the old Windows Print Screen habit.
For a simpler option, use a browser screenshot extension for web-based tutorials.
Install one from the Chrome Web Store. Pin it beside the address bar. Click it, then choose:
Full page for an entire webpage.
Visible area for the current screen.
Selected area for one section.
The extension saves each screenshsot or copies it to your clipboard. This works well for school pages, Docs, and work dashboards, becuase you avoid memorizing Chromebook shortcuts.
If your Chromebook came from your school or your job, check whether screenshots are even allowed before you spend an hour learning shortcuts. Managed Chromebooks can have screen capture and screen recording locked down by the admin, and when that happens the key combo just does nothing with no error. I’ve seen people assume their keyboard is broken when it’s actually a policy. If Ctrl + Show windows does nothing and the Screen capture button is missing from the quick settings, that’s your sign. You’d have to ask whoever manages the devices.
That aside, the shortcut advice in here is solid. Where I land differently from @caminantenocturno is the clipboard history pitch. It’s genuinely handy, but the plain clipboard only holds one item, so if you take three screenshots in a row and only paste once, the first two are gone unless you turned on Search + V history first. People forget that and lose captures. If you’re doing rapid-fire grabs for a tutorial, just let them save to the folder and grab them from Files afterward. Less to think about mid-flow.
The browser extension @alphaforge5213 mentioned is worth a caveat too. Those are fine for a single webpage, and the full-page scroll capture is something the built-in tool can’t do, so it fills a real gap. But it only sees inside the browser tab. The second you need to screenshot a settings menu, the shelf, a system dialog, or anything outside Chrome, it’s useless. So it’s an add-on, not a replacement for the native shortcuts.
One small thing nobody flagged: the saved files are PNGs, and full-screen shots on a high-res display can get chunky if you’re pasting a pile of them into one Docs file. For work tutorials that get shared around, partial captures aren’t just cleaner to look at, they keep the file size sane too.
If it turns out your device does block capture, a phone photo of the screen is the ugly fallback nobody wants to admit works.
