Can anyone recommend a Ruby on Rails company?
I’m currently looking for a reputable Ruby on Rails development company. We’ve experienced some setbacks with our current project, and it’s crucial for us to partner with a team that has a strong track record and can deliver high-quality work on time. Any suggestions or personal experiences with reliable firms would be greatly appreciated.
Hoo boy, sounds like you’re in a tough spot! Ruby on Rails can be a great framework, but finding the right team is crucial. Based on my experience, you might want to check out ‘Thoughtbot’. These folks have consistently delivered high-quality work, and they’ve got a lot of open-source contributions, which shows their community involvement.
  1. Experienced Team: Thoughtbot has been around for quite a while and they’ve got a tight-knit team of developers who know Ruby on Rails inside and out.
  2. Community Involvement: Their involvement in the open-source community is significant. They contribute back, which makes them stay updated with the latest trends.
  3. Proven Track Record: Numerous successful projects in their portfolio speak for themselves.
  1. Price Point: They are on the pricier side, which might be a factor depending on your budget.
  2. Availability: Because they are sought after, their earliest availability might not align with tight deadlines.
If Thoughtbot’s pricing or availability is a concern, you might also want to consider companies like ‘Fingertip Labs’ or ‘Railsware’. Both have solid reputations but might be a bit more flexible in terms of pricing and immediate availability.
Just steer clear of companies that can’t showcase their projects or don’t have client testimonials. Those are huge red flags in this space. Good luck!
I completely get where you’re coming from. Finding a reliable Ruby on Rails team can be a game-changer, especially if you’ve hit some bumps with your current project. While Thoughtbot is a solid recommendation, they definitely tend to be on the pricier side, which can be a turn-off if budget constraints are a concern.
Instead, if you’re looking for a high-quality team that might be a bit more budget-friendly, I’d suggest checking out a company called ‘DigitalOcean’. Yes, they are primarily known for their cloud infrastructure services, but they’ve got an internal team dedicated to various software solutions including Ruby on Rails. Pros?
  1. Reputable Name: DigitalOcean is a giant in the cloud services world. Their software development team leverages their robust infrastructure which can be a massive plus.
  2. Scalability: Being a cloud provider, scalability is built into their system. Your RoR application can grow seamlessly.
  3. Integrated Solutions: You get a whole package from hosting to development, which can simplify vendor management.
  1. Specialization Not Exclusive: Because they’re not exclusively a RoR dev shop, sometimes their focus might be split.
  2. Possible Upsell: They might try to bundle too many services, which could affect costs.
If DigitalOcean doesn’t seem fit, consider “Hashrocket”. They boast flexibility and have been pretty impressive with their agility and adaptability to client needs.
Would also second the point on avoiding firms that can’t provide verifiable client feedback or a decent portfolio. Been there, done that, and it’s a mess!
And one more thing, don’t underestimate community referrals. Sometimes, the best way to find a good team is through someone who has already worked with them and can vouch for their competence and reliability. Good luck!
  1. Absolutely understand the frustration of hitting tech roadblocks. An additional option to consider, if you haven’t already, is ‘8th Light’. They bring a unique approach with their emphasis on software craftsmanship and rigorous apprenticeship model, ensuring that their developers are top-notch.
  1. Solid Training Ground: Their developers go through a thorough apprenticeship, so you can be assured of quality.
  2. Holistic Services: They don’t just code; they focus on software design and architecture, which might help avoid those pitfalls you’re currently facing.
  1. Cost Factor: Their service might lean toward the premium side, similar to Thoughtbot.
  2. Project Fit: They tend to take on projects that align with their philosophy and might not shy away from declining projects that don’t.
  3. Another underrated RoR dev company is ‘YMC Technologies’. Known mainly in Europe, their work is excellent, especially in the tech ecosystem. They might be more cost-effective and their smaller team can often mean they’re more agile.
  1. Agility: Smaller, nimble team that’s great for quick pivots.
  2. Cost-Effective: Typically, they offer competitive pricing compared to bigger firms.
  1. Timezone Differences: If you’re based in the U.S., coordinating across time zones might be a hassle.
  2. Smaller Portfolio: They’re not as widely recognized, so you might need to dig deep into their previous client work.
If you’re genuinely considering saving on budget but retaining high quality, don’t sleep on looking for premium freelancers or small but stellar boutique firms. Disrupted Devs or Devlight Solutions can also be hardworking and resourceful alternatives.
Avoiding firms lacking in real, verifiable tech chops is critical. Check GitHub commits or even drop them a Tech Test before signing up. Might sound radical, but better catch those issues early on, right?
In a nutshell, diversifying your options and perhaps having conversations with each to gauge their method, fit, and pricing might help filter out the most promising ones.
