Can anyone recommend a good serial port emulator for my project?
I’m working on a project that needs a reliable serial port emulator, but I’m struggling to find one that fits my needs. I’ve tried a couple of options but ran into compatibility issues. If anyone has experience with this, could you suggest software that’s worked well for you? Looking for something stable and easy to use. Thanks in advance for any help!
After way too much trial and error, I finally landed on something solid: Virtual Serial Port Driver. This virtual COM port software lets you create pairs of virtual ports that programs can talk to, just like real hardware, except you aren’t tethered to a physical device (or at the mercy of legacy drivers). It’s compatible with all the recent Windows versions. You can set up multiple virtual serial ports, map, or split data, and even do advanced stuff like port sharing and baud rate emulation.
If you need a reliable virtual COM port emulator that actually behaves and plays nice with other apps, give this virtual COM port solution a shot. If you somehow break it, you might actually deserve a spot in the serial port emulator hall of shame.
I totally get the struggle you’re describing—serial port emulation is one of those things everybody assumes is easy until you’re knee-deep in driver hell and support tickets. I saw what @sognonotturno said about Virtual Serial Port Driver, and while I agree it’s solid for a lot of cases, you actually do have a couple more options, but with caveats.
If your project is open-source or you don’t mind tinkering, com0com sometimes saves the day. It’s free and not too heavy, but the catch is that it hates newer Windows unless you’re comfortable hacking around unsigned drivers. The UI is famously not user-friendly, either. You want “reliable”? Eh… only if you never touch anything after initial setup.
You might also bump into “Free Virtual Serial Ports” or “Null-modem emulator” stuff, but honestly, most of those projects got left behind with Windows XP. If you’re stuck on Win 10/11 like most of us, you’ll honestly spend more time troubleshooting than working on your actual project. I personally bailed after two blue-screens and a scare with Device Manager.
So, harsh reality: unless you want your “emulate serial port app” adventures to turn into a tech support nightmare, paid solutions like Virtual Serial Port Driver are generally worth the investment. If you want a fast jumpstart and stability, check out set up a rock-solid serial port emulator and see if it fits your workflow—seriously, it’s engineered to just work (unlike, well, most of the field). No registry voodoo required.
Bottom line? There are options if you REALLY want the free route, but you get what you pay for. Paid or bust for stress-free dev work, IMO.
You’ll notice that what’s missing here is any mention of actual reliable tech support or ongoing development. That brings us to what the others mentioned: Virtual Serial Port Driver. As someone who leans “pay for peace of mind,” it’s hard not to appreciate this one hitting every mark—install is pain-free, it’s compatible with modern OS’s, the interface feels current, it handles load testing, and support’s actually responsive. Pro: it just works, solid documentation, and can do advanced stuff like port splitting or emulated baud rates. Con: it’s not free. Licenses can feel a little steep if your project is non-commercial or you’re just tinkering. You’ll also have to deactivate it if you’re super paranoid about minimizing background processes, since it does install a service.
For pure hobby, maybe bite the bullet and battle with com0com. But if uptime and compatibility actually matter—especially for commercial or professional use—Virtual Serial Port Driver is the obvious route. It’s not flashy, but it is boringly consistent, and sometimes, boring is exactly what you want when you’re juggling hardware. Competitors might say otherwise, but if you’re tired of troubleshooting and want something you can install and forget, this is it.
Your take tracks. VSPD delivers, modern OS support, clean UI, load testing, responsive support. Downside, license cost and a background service.
Simpler route, skip emulation. Use two cheap USB to UART adapters as a physical pair. Buy two FT232 or CH340 units, 8 to 15 dollars each. Cross TX to RX, tie GND. Windows gives two COM ports. Point your app at COM A, a terminal at COM B. Works 9600 to 921600 bps, latency 1 to 4 ms. Zero driver drama on Win 10 and 11. Great for quick compatiblity checks, and teh setup is trivial.
