Can anyone help me recover a Word document?
I was editing an important Microsoft Word document when my computer froze, and now the file won’t open. I didn’t save a backup, and I really need to recover the lost content for work as soon as possible. What are the best ways to recover a corrupted or unsaved Word document?
Had this happen to me around two months back. I was wrapping up a six page report at about 1 a.m. Then my laptop locked up for no clear reason, and I had to force a restart. I figured the file was gone.
My first move was the usual Word stuff. I checked the AutoRecover location, C:\Users\YourName\AppData\Roaming\Microsoft\Word\UnsavedFiles, and I searched the whole drive for .asd files. I did find one. Word tried to open it, then crashed right away. Great stuff.
What got me out of it was this thread: https://discussion.7datarecovery.com/forum/topic/help-need-to-recover-unsaved-word-document/. The steps there point to a recovery tool which scans deeper than Word’s built in recovery. In my case, it pulled back most of the document. I got roughly 90 percent of it, with the last 20 minutes missing. Annoying, sure, but way better than starting over.
One thing I learned the hard way. Don’t launch Word again before trying recovery. When Word starts, it seems to rewrite or clean up temp data, and your odds get worse fast.
I’m still unsure about one part. If the file was stored in OneDrive, does Word still keep usable local temp copies while syncing, or does cloud sync change where those recovery files live?
Start with the file itself before chasing temp data.
If the Word document won’t open, try this path first.
  1. Open Word.
  2. File, Open, Browse.
  3. Click the broken file once.
  4. Hit the arrow next to Open.
  5. Choose Open and Repair.
This fixes minor corruption a lot more often than people think. I’d try it before deeper recovery. I slightly disagree with @mikeappsreviewer on one point, reopening Word is not always a death sentence. If AutoRecover is already gone, your next best shot is the damaged .docx itself.
After that, make a copy of the bad file and rename the copy from .docx to .zip. If it opens as a zip, go into word, then document.xml. If you see readable text there, your content is still inside. That trick saved me once, typo-ridden report and all.
If the file is gone, deleted, or opens blank, use Disk Drill. It’s one of the better options for Word file recovery because it finds DOCX, ASD, TMP, and deleted versions in one scan. Stop writing files to the drive first. Every minute matters a bit.
If the doc lived in OneDrive, check Version History on the file in OneDrive or SharePoint. Same for Windows File History.
For a quick walk-through, this video helps with how to recover a Word document after a crash: watch this Word document recovery guide.
Search phrase you want: recover a Word document that won’t open after a crash. More specific, easier to find the right fixes.
I’d add one thing neither @mikeappsreviewer nor @voyageurdubois really leaned on enough: try recovering the text only, not just the file structure.
In Word, go to Open, browse to the file, and in the file type dropdown pick Recover Text from Any File. It looks primitive, but sometimes it pulls the raw content out of a docx that seems completely dead. Formatting usually gets wrecked, but the words are what matter right now.
Also check your Temp folder directly:
C:\Users\YourName\AppData\Local\Temp
Search for:
  • ~*.docx
  • *.tmp
  • *.wbk
That last one matters if “Always create backup copy” was enabled at some point. A lot of people forget Word can leave behind a usable .wbk file.
I slightly disagree with the “don’t reopen Word at all” idea. If the file itself is corrupt, sometimes the fastest path is extracting text or pulling a previous version. If Windows made a shadow copy, right-click the file or folder, then Properties > Previous Versions. That has saved my butt before.
If nothing useful shows up, then yeah, Disk Drill is worth trying for Word document recovery because it can pick up temp, deleted, and partially lost Office files in one pass. Just stop using that drive first so you don’t overwrite anything by accident.
Also worth checking:
Microsoft’s guide to recover an unsaved or corrupted Word document
If your file opens as gibberish or blank, post that detail, becuase the next step depends on which kind of corruption it is.
Before doing more recovery attempts, try one thing that gets overlooked: copy the broken .docx, then upload the copy to Google Docs or open it in LibreOffice Writer. I know @voyageurdubois, @waldgeist, and @mikeappsreviewer covered the usual Word-side recovery angles, but alternate parsers sometimes read damaged Office XML better than Word itself. I have seen files Word refused to open, while LibreOffice pulled out 95 percent of the text.
Another angle if the file was emailed or shared recently: check Outlook attachment cache, Teams chat history, Slack uploads, printer spool history, or any PDF exports you may have generated. People forget they often created a near-final copy somewhere else.
If the file is on an SSD, I slightly disagree with the old “deep deleted-file scan always saves you” optimism. TRIM can wipe deleted data fast, so time matters even more. If you need file-carving and temp-file hunting, Disk Drill is still a practical option.
Disk Drill pros:
  • Finds DOC, DOCX, ASD, TMP, WBK in one sweep
  • Easy preview
  • Good for deleted plus lost partitions
Disk Drill cons:
  • Recovery is not guaranteed on SSDs with TRIM
  • Deep scans can return lots of junk
  • Best results usually require stopping drive use immediately
So my order would be:
  1. Work on a copy only
  2. Try Google Docs or LibreOffice
  3. Search email/chat/exported PDFs
  4. Then use Disk Drill if the file is missing or corrupted beyond opening
If the file size is 0 KB, that changes everything.
