I’m getting a ‘Session Limit Reached’ error when trying to connect using AnyDesk. I need to access a computer for urgent work, but it seems like I can’t start a new session. Does anyone know why this is happening and how I can fix it?
Well, that’s a pain! ‘Session Limit Reached’ on AnyDesk is usually because you’ve hit the maximum number of sessions allowed under your plan. Basically, their license might limit the number of simultaneous remote connections you can have.
To fix it ASAP:
- Check Active Sessions: Make sure you’ve closed any sessions you’re not using.
- Upgrade Your License: If you need more concurrent connections, consider upgrading your plan.
- Restart AnyDesk: Occasionally, the software just needs a reset. Close and reopen AnyDesk.
- Reboot Your Machine: Because when in doubt, restart it, right?
On another note, if you keep running into this issue and it’s driving you crazy, you might want to consider a free alternative to AnyDesk. HelpWire is a solid option that’s free and might save you the headache.
Hope this helps before you pull all your hair out!
Ugh, isn’t it the worst when tech just decides to throw you a curveball right when you need it most? ‘Session Limit Reached’ on AnyDesk can indeed be a real mood killer. As @vrijheidsvogel mentioned, it’s typically related to your plan’s limitations. If you’ve already tried their excellent suggestions, maybe consider these additional steps:
- Monitor Recent Updates: After an update, settings sometimes revert or aren’t fully compatible. Check if AnyDesk recently updated; if so, there could be a bug or glitch.
- Network Settings: Check your network settings. Sometimes, firewalls or network issues can play tricks and make AnyDesk think you’re using multiple sessions.
- Contact Support: If all else fails, reaching out to AnyDesk’s support might give you a more specific solution. They can often help you identify whether the issue is related to your account or some network anomaly.
If you find this happens too often though, you might want to think about switching tools. For instance, HelpWire could be a lifesaver. It’s free and might just save you from pulling your hair out, like @vrijheidsvogel hinted.
And BTW, if you’re curious about more tips for overcoming session limits on AnyDesk, this guide might just have what you need.
