I’m trying to track how my target keywords are ranking in Google and other search engines, but most tools I find are either paid or limit keyword checks heavily. I need a reliable, truly free keyword rank checker to monitor positions, see changes over time, and help with basic SEO optimization for my site. What free tools are you using that actually work for ongoing keyword rank tracking, and what are their limitations?
Short answer. There is no perfect, truly free rank tracker with zero limits. But you can get close if you mix a couple tools.
Here is what works well without paying.
Whatsmyserp Free SERP Checker
- Unlimited checks per day if you do them manually.
- Lets you pick country and device.
- No login for basic checks.
- Good for quick spot checks of 1 keyword at a time.
Use it to sanity check your main money keywords.
SERPRobot Free Checker
- Lets you track up to 10 keywords for 1 domain free.
- Daily tracking.
- Google only, no Bing etc.
- Nice if you want a simple “set it and forget it” graph.
Mangools SERPWatcher Trial, recycled
- Free trial is 10 days, but you do not need it every month.
- Use it for bigger audits. Export the initial baseline.
- Repeat again in a few months with a new email if you want snapshots.
- Helps you see if your long tail terms move up or down.
Google Search Console
- You already have this, but use it like a rank tracker.
- Go to Performance → Search results.
- Filter by query, then by country.
- Sort by “Average position”.
- Export once per week or once per month to Sheets.
- This is not a “pure” rank number, it is an average, but for trend tracking it is reliable.
- Use it to track 20 to 100 target queries over time.
Simple spreadsheet system
- Create a Google Sheet with columns: Date, Keyword, URL, Country, Device, Rank.
- Once per week, check your 10 to 20 highest priority keywords in Whatsmyserp or SERPRobot.
- Fill the sheet.
- After a month you will see if things go up or down.
- This avoids hitting tool limits since you are not tracking 100s of phrases.
If you need “set and forget” tracking for more than 10 to 20 keywords across multiple search engines, free tools start to break. Free plans cap features because rank tracking costs server time.
So, best mix for zero spend right now:
- Whatsmyserp + SERPRobot for ranking checks.
- Google Search Console for trends and real clicks.
- A manual spreadsheet workflow to glue it together.
It is a bit more work, but once you set the routine, it takes like 15 minutes per week and you avoid paid tools.
@sternenwanderer covered the “mix a few tools” approach pretty well, so I’ll throw in some alternatives and a slightly different take.
First, tiny bit of reality check: there is no truly free, unlimited, automated rank tracker that’s reliable over time. Anyone claiming that is either scraping like crazy (and will die soon) or lying in their marketing.
That said, here’s what actually works decently without paying, without repeating what was already mentioned:
Ubersuggest free plan
- Yeah, it’s heavily paywalled, but the free version still gives you a few daily rank checks and some tracked keywords.
- Good for small sites or a handful of core keywords.
- The upside: you get a bit of site overview + rankings in one place.
- The downside: aggressive upsells and daily limits, so this is more “quick check” than “serious tracker.”
SE Ranking free trial used strategically
- Not a long term free tool, but useful if you’re in “benchmark mode.”
- Add all your target keywords, let it run for the trial period, export everything.
- Repeat once or twice a year when you’re planning a bigger strategy change, not as your regular weekly tracker.
- I actually prefer this kind of concentrated snapshot vs limping along with ultra-limited free plans.
GSC + manual SERP checks + browser tricks
Slight disagreement with relying too much on third-party rank trackers: for most small sites, your combo of:- Google Search Console “Performance” report for trends and opportunities
- Manual incognito Google checks for your top 5–10 money terms
- Location simulation (SEO Minion extension, or changing
&uule/ using a VPN)
is honestly enough.
This avoids getting obsessed with exact position numbers on 100+ keywords that never bring traffic anyway.
Privacy-friendly rank checker scripts
If you’re even a bit techy or have cheap hosting:- There are simple open source rank checker scripts in PHP / Python that query the SERPs in a slow, respectful way, then log positions in a DB.
- You get “set and forget” tracking without paying monthly.
- Catch: you need to install, configure and occasionally babysit it, and you have to respect search engine TOS / rate limits.
- Not for everyone, but it is probably the closest thing to “free forever” if you’re comfortable with light dev stuff.
What I’d actually do with zero budget
- Pick 10–20 truly important keywords (high intent, not vanity terms).
- Once a week:
- Check exact rank manually in Google using an incognito window + location tweak.
- Log that in a simple sheet along with GSC average position and clicks.
- Once a month:
- Run a “snapshot audit” using a trial or limited free plan (Ubersuggest, SE Ranking, etc.) and export everything.
- Ignore the rest. Most people waste time tracking 300 unimportant phrases instead of fixing pages and content.
If you’re expecting a magic free tool that monitors 200 keywords daily across multiple search engines forever, it just does not exist in any stable way. But a mix of GSC, manual checks, a periodic trial, and maybe a small script if you’re technical will actually give you a pretty clear picture of your progress without paying a subscription.
Short version: there is no “truly free, unlimited” rank tracker, but you can get close enough by combining a few half-decent options and lowering the ambition from “track everything daily” to “track what actually matters, regularly enough.”
Since @sternenwanderer already covered the multi‑tool combo, here are some different angles and tools you can lean on.
1. Use GSC more aggressively than most people do
I actually disagree a bit with treating Google Search Console as just a trends tool. If you work it properly, it becomes your core rank tracker:
- Filter by specific query or group of queries
- Compare last 28 days vs previous 28 days
- Look at impressions + CTR + average position together
- Export to Sheets and keep monthly snapshots
You do not get precise daily rankings, but you absolutely see whether a keyword is moving up or down in a way that actually matters for traffic. For most small and medium sites, that is more useful than hyper‑granular position tracking on 100 keywords.
- 100% free
- Direct from Google
- Shows real clicks, not just positions
- No per‑day, per‑device position graph per keyword out of the box
- No nice “rank tracker” UI
2. SERP APIs + a simple sheet (closest thing to “free forever” if you are tech‑curious)
Instead of full rank tracking SaaS, you can:
- Use a low‑cost or freemium SERP API
- Write a simple script (or no‑code automation) that:
- Takes a list of keywords from a sheet
- Hits the API once per day or per week
- Writes back positions into the sheet
Cost can be almost nothing if you limit keywords and frequency. This avoids the “tool paywall” issue and you own the data.
- Very flexible, you track only what you need
- No lock‑in to a specific UI or tool
- Can respect rate limits and TOS better than random scrapers
- Requires some tech setup or willingness to follow tutorials
- Not a polished one‑click interface
If you ever come across a product like “What’s the best free keyword ranking tool to track my SEO progress?” packaged as a small script or micro‑tool instead of a full SaaS, this is exactly the model it usually uses.
Pros of that kind of “DIY rank checker” product
- One‑time setup instead of subscription
- Highly customizable keyword lists, locations, schedules
- Data export is trivial since it is your own environment
- No dedicated support team, you are the support
- UI is usually basic or non‑existent
- If Google adjusts SERP markup a lot, you may need to update the script
3. Structured manual tracking that does not waste your time
Here is where I think both you and @sternenwanderer can easily overcomplicate things. You do not need to track 200 terms to understand your SEO progress.
Try this setup:
- Choose 5–15 “money” keywords and 5–10 supporting ones
- Once every 1–2 weeks:
- Check Google in a clean browser or separate profile
- Always use the same location (VPN or consistent geo setting)
- Record exact position, page URL, notes in a sheet
- Every quarter: compare those points with GSC trends
That gives you enough signal to see whether your efforts are working, without getting obsessed with minor daily position swings.
- 100% free
- Very realistic view of your SERPs
- Forces focus on the keywords that matter
- Manual and a bit boring
- Easy to get inconsistent if you skip weeks or change location/device
4. Lean on “side features” in free tools, not only rank modules
Where I disagree slightly with the “just use a trial” approach: some tools are still useful on their crippled free plans if you focus on what they do give for free rather than trying to use them like full trackers.
Examples of what to look for in free versions:
- “Top pages” or “top keywords” reports for your domain
- “Keyword difficulty” and “SERP overview” for a small number of terms per day
- Historical snapshots of your domain’s visibility
That way, even with limits, you still get trend‑level insight about how visible your site is and which keywords are rising vs falling, without trying to track everything every day.
5. When you actually should pay something
If your business really depends on organic search and you are past the hobby stage, then the honest answer is:
- Use the free stack above for 2–3 months
- If you are still actively optimizing, invest in a cheap, low‑tier paid plan somewhere
A lot of people spend more monthly on coffee than on tools that show if their business is growing. At that point, stressing over the “perfect free keyword rank checker” becomes a false economy.
So, if you want a “no BS” setup on zero budget:
- Make GSC the core
- Maintain a tight sheet for 10–25 critical keywords with manual checks
- If you are even slightly technical, add a light script or SERP API combo to automate part of it
- Use occasional free trials only for broader visibility audits, not as your main tracker
That will track your SEO progress reliably enough without falling into the “free unlimited rank tracker” myth that never really delivers.
