Need help finding the right charger for my iPhone 17 Pro
I just got an iPhone 17 Pro and realized my old charger is either too slow or not compatible. I’m trying to figure out which charger block and cable will give me the best charging speed without damaging the battery. I need help choosing the right iPhone 17 Pro charger so I don’t waste money on the wrong one.
Get a USB C power adapter rated 20W or higher. For iPhone fast charging, Apple targets about 20W to 27W, depending on the model and battery level. A 30W USB C charger is a safe pick. It won’t force too much power into your phone. The phone only pulls what it needs.
Best simple options:
Apple 20W USB C charger
Apple 30W USB C charger
Anker 30W Nano
Belkin 25W or 30W USB C PD charger
Use a USB C cable rated for charging. If your iPhone 17 Pro has USB C, use USB C to USB C. If you still need Lightning for an older model or accessories, use USB C to Lightning. MFi or USB-IF certified is worth it. Cheap no-name cables are where ppl get weird issues.
For battery health, fast charging does not “damage” the battery in normal use. Heat does more harm. Avoid charging under a pillow, in a hot car, or with a junk charger. Turn on Optimized Battery Charging in Settings. If you want less heat overnight, use a slower 5W to 12W charger while sleeping. For daily top-ups, 20W to 30W is the sweet spot.
You mostly need to match the standard, not chase some magic Apple-only brick. @sonhadordobosque is right on USB-C PD, but I’d push one detail a bit: I’d skip the 20W if you’re buying new and just get a quality 30W or 35W charger with PPS support if possible. The iPhone won’t use all of it, but those chargers tend to run cooler and also work better for iPads, earbuds, travel, etc.
What I’d buy:
  • 30W USB-C PD wall charger from Apple, Anker, Belkin, UGREEN
  • USB-C to USB-C cable, ideally USB-IF certified
  • If you want flexibility, a 2-port charger is nice, but dont use both ports if you want max phone speed
One thing ppl overthink is “battery damage.” The bigger issue is heat + staying at 100% for hrs, not using a proper fast charger. So if you want max speed, use 20W to 30W wired. If you want lowest stress overnight, MagSafe or wired on a lower-output brick is fine, just slower obv.
Also, avoid gas station cables. Thats where the weird gremlins live.
